Make it stop!!!svchost.exe - Application Error
The instruction at "0x009a96bc" referenced memory at "0x00000000". The memory could not be "written".
Click on OK to terminate the program
Click on CANCEL to debug the program
HELP BEFORE I GO CRAZY!
- Amy
I need help: How do I get rid of this error message that unceasingly appears?
- Apoptosis
- Site Admin
The svchost.exe file is located in the c:\windows\System32 folder. In other cases, svchost.exe is a virus, spyware, trojan or worm!"Svchost.exe" (Generic Host Process for Win32 Services) is an integral part of Windows OS. It cannot be stopped or restarted manually. It manages 32-bit DLLs and other services. At startup, Svchost.exe checks the services portion of the registry to construct a list of services that it needs to load. In normal conditions multiple instances of Svchost.exe run at the same time. Each Svchost.exe session can contain a grouping of services, so that separate services can be run depending on how and where Svchost.exe is started. This allows for better control and debugging.
Run Spybot and Adaware to remove your spyware.
- killswitch83
- kenc51
goto start / run - type "SFC/SCANNOW" (without quotes)
Have your XP cd in the drive - windows will ask "do you want to scan all system files for integrity?" --> choose yes
This will scan all system files and folders, replace/repair all automatically
If this fails - you can try system restore - start / all programs/ accessories / system tools / system restore
choose a date as close as possible to the date when this happened
Remember that any updates (av software etc.) will be lost
Svhost.exe covers a whole load of stuff in XP --> are you using XP's inbuilt firewall? --> or any software firewall --> sometimes firewalls will cause this error!
- killswitch83
Hmm, yet another thing to put in the book in my mind, lol. I didn't know the firewall that came with Windows would cause Svchost errors. Good thing I don't use it, and actually I'm looking for a good one. I used to use ZoneAlarm, but when I build my new system I plan on using something more comprehensive. I know one I was wanting to try but couldn't because it ate the hell out of my system resources was SyGate. I heard it can block a buttload of exploits.
- kenc51
SyGate is a good firewall... but only if you want to have something like 10 clients connected behind your firewall (essentially your going to run you box as a firewall) -- this is for people who are gonna use VPN - plus if you need to set some pc's to work in a DMZ or if you need to forward port 80 etc..
I doubt your gonna need that? -> if you do.. then get a cheapo box setup and run a Linux firewall LOL
- killswitch83
ohh, man I thought it was a personal firewall. Well, I'll have to remember that when I set up my home network. Then I can figure out how to set up a separate box on the network to operate as a firewall (remember, I'm only in part 2 of the CCNA prog, lol). Know of any good personal firewalls that don't have many exploits, if any at all?
- kenc51
Software Firewalls are only as good as the code their written in!
I don't use any personally @ the moment (just the one built into my linksys router)
I normally use SUSE Linux as my gateway/Firewall/bittorrent box
If you want to use a seperate box for a firewall, then Smoothwall (Linux)... Is easy to configure and has more than enough options (even for a Cisco guy like you lol)
Smoothwall boots from cd, so all files are read-only (better protection) = only issue is it's not customisable
For windows ZoneAlarm is good (stealths all ports by default and asks for confirmation b4 allowing outbound connections)
I like Tiny personal firewall - uses almost no resourses and again has more that enough options
Kerio firewall is also supposed to be good too
@ Amy - Did any of that help????
- kenc51
Actually my bad... SyGate is a personal firewall.... I was thinking CheckPoint or Wingate or something..... (can't remember - just finished supporting this cr*p for the last 8hrs lol)killswitch83 wrote:ohh, man I thought it was a personal firewall. Well, I'll have to remember that when I set up my home network. Then I can figure out how to set up a separate box on the network to operate as a firewall (remember, I'm only in part 2 of the CCNA prog, lol). Know of any good personal firewalls that don't have many exploits, if any at all?
- Amy
Yes, we do have 2 HP Printers installed, and one is an all-in-one! Well, Norton didn't find anything, and the next time I reboot Windows is supposed to run scandisk. After that, I'll get on HP's website and check for new drivers. I'm at work tonight, so I'll have to do that tomorrow. Thanks for everyone's advice...I hope something works!
well, if you want the best- go hardware instead of software. get a router hooked up before your rig. your computer will be hidden from others and it won't eat any system resources. you will still need a separate app against spyware (spysubtract works fine for me running in the background, in addition I check with noadware,ad-aware, spybot S@D, xoftspy) and viruses (kaspersky won out of 37 different antivir and it auto updates deffinitions every 4hours)killswitch83 wrote: Know of any good personal firewalls that don't have many exploits, if any at all?
mega antivirus test (kaspersky won):
http://www.overclockers.com/articles1260/
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte B550 Aorus Elite, Ryzen 5800X @ stock, 32GB Patriot Viper DDR4 3200Mhz 16-18-18-36-1T, AMD RX 5700XT + AlphaCool WC, ACER Nitro XV2 27", SP 1TB nvme PCiE GEN3, Samsung 2TB; Cooler Master MW Gold 650W, Win10 Pro 64
- killswitch83
Hey, it's all good. I already got my Firewall/AV combo set up (AVG and ZoneAlarm). So far so good, using both right now on this little POS I have, and it doesn't seem to be bogging down performance too badly, while catching things it should. I already knew about ZoneAlarm, but needed opinions about it, so it pretty much reinforced my opinion of em, thanks for the help guys
btw, thinking about later on investing in a hardware firewall by Cisco, lol...talk about security
You tried disabling third-party browser extensions?
Sometimes even after a program removes spyware, a few bits and pieces are left over. So if you don't use any IE extensions... you can try and disable it in Internet Options > Advanced.
Worked for one person I know who got infected with an obscure spyware strain that couldn't be completely removed.
wasn't CWS (coolwebsearch)? that was the nastiest spyware I've ever got on my rig. it took me 1 week of strugle, before I found CWS shredder (freeware) that was made to anihilate it. CWS shredder is also included in spysubtract pro (not free) which I'm using now. never had any more problems with itKerii wrote: Worked for one person I know who got infected with an obscure spyware strain that couldn't be completely removed.
- killswitch83
Apparently it's a conflict between WIA(Windows Image Acquisition ) and the HP scanner/printer monitoring app.Amy wrote:Yes, we do have 2 HP Printers installed, and one is an all-in-one! Well, Norton didn't find anything, and the next time I reboot Windows is supposed to run scandisk. After that, I'll get on HP's website and check for new drivers. I'm at work tonight, so I'll have to do that tomorrow. Thanks for everyone's advice...I hope something works!
many have had it work fine with WIA disabled.
Sorry, didn't save the links, google around with the error message
