What is the best mobile phone signal booster?
Rilan
Legit User
Legit User
Postby Rilan » Wed Dec 27, 2017 3:27 am
I decided to buy a mobile phone signal booster because nothing helps. Which one should I choose?
KnightRid
Re: What is the best mobile phone signal booster?
Postby KnightRid » Wed Dec 27, 2017 5:25 am
Get one from your cell provider. None of those crap ones that stick to your phone as they don't work. You have to make sure the one you get works with the provider and phone you have so if you want any suggestions on actual products you would have to tell us which carrier and which phone you are going to be using it with.
They also have some that can hook to your internet connections to use your cell phone through wifi, as long as you have good wifi.
Dooles
Legit User
Legit User
Postby Dooles » Wed Dec 27, 2017 8:31 am
Awesome tips, KnightRid. I think a mobile signal booster is the best solution in this case. Besides, I had such problem and know that it really works. Check out his website - https://www.mobile-signal-boosters.co.uk/
Who is online
