The full tower market has been getting a bit more crowded lately and that causes manufacturers to try and find unique ways to set themselves apart. NZXT is one that is well known for doing things to set itself apart and recently sent us their latest incarnation, the Switch 810. Read on to see if the extra features make us ho hum or say WOW!
We were very impressed with several of the innovative features that NZXT put on the Switch 810, especially the consideration for pretty extreme water cooling setup with that 85mm of top clearance. The ability to drop a 420mm rad in the top and another 280mm rad in the bottom should be enough cooling for even a quad GPU setup. Placing easy to access filters on the intake fans is a real plus and should keep the dust bunnies to a minimum.
Article Title: NZXT Switch 810 White Case Review
Article URL: http://www.legitreviews.com/article/1844/1/
