Corsair Unveils Carbide Air 540 and Carbide 330R Cases
Postby Apoptosis » Mon Jun 03, 2013 1:46 pm
New Corsair PC Cases Get the Cool and Silent Treatment
– Corsair Unveils Carbide Air 540 and Carbide 330R Cases at Computex 2013 –
Carbide 330R
Carbide Air 540
Carbide Air 540
Carbide Series Air 540 Back
COMPUTEX 2013 — TAIPEI, Taiwan — June 4, 2013 — Corsair®, a worldwide designer of high-performance components to the PC hardware market, today announced two new mid-tower PC cases—the Carbide Series Air 540 and the Carbide Series 330R. Both cases incorporate innovative and unique features for superior cooling and quiet operation.
Carbide Series Air 540 High Airflow Mid-tower PC Case
The Carbide Series Air 540 is designed with a wider form factor with two “side-by-side” chambers and a Direct Airflow Path™ layout. This unique design helps the case deliver best-in-class cooling at incredibly low noise levels.
The main chamber of the Carbide Series Air 540 houses the motherboard and hot-swap 3.5” drives for superior drive cooling and quick swapping. The second chamber holds the power supply, SSDs, and 5.25” drives behind the motherboard tray. The separate compartments make building a breeze and provide cleaner cable routing and superior cooling for system devices. In addition, layout in each chamber is optimized to limit obstructions and streamline airflow from the intake fans to the hottest PC components, resulting in lower temperatures and noise levels.
• Support for Mini ITX, Micro ATX, ATX, Extended ATX motherboards and ATX power supplies
• Eight tool-free expansion slots that supports cards lengths up to 12.5” (320mm)
• Mount points for six 120mm or five 140mm fans (or 240/280mm radiator on top and 360/280/240mm radiator in front)
• Two 5.25”, two hot-swap 3.5”, and four 2.5” tool-free drive bays
• Removable front magnetic low-restriction dust filter
• Built-in cable routing cutouts with grommets
• Two USB 3.0 ports plus headphone/mic jacks on front panel
• Oversized flush-mount window
• 16.5" (407mm) deep x 17” (432mm) wide x 18" (457mm) tall
Carbide Series 330R Quiet Mid-tower PC Case
Corsair announces the quiet, attractive Carbide Series 330R for low noise home computing. Unlike other products targeted towards the low-noise fanatics, the Carbide Series 330R is designed for both low noise levels and excellent cooling performance at an attractive price point. The case is laid out with a Direct Airflow Path from the 140mm front intake fan to provide efficient cooling to the hottest components. Noise dampening material on the top panel, side panels, and front door combined with rubber feet help keep the PC quiet, and the top panel can be removed for 240mm radiator installation if desired. Couple that with features like built-in USB 3.0 and SSD capabilities and the 330R is an attractive solution for the low noise enthusiast.
• Noise dampening material on the top panel, side panels, and front door
• Direct Airflow Path
• Up to Five fan mount locations (front 120/140mm x 2, top 120/140mm x 2, rear 120mm)
• USB 3.0 on front panel
• Four hard drive trays with dual HDD and SSD compatibility
• Tool free 5.25” and 3.5” drive installation
• 19.5” (495mm) deep x 8.3” (210mm) wide x 19” (482mm) tall
“Corsair cases are known for being good looking, easy to build, and highly configurable,” commented Thi La, Senior VP and GM of Memory and Enthusiast Component Products at Corsair. “The Carbide Air 540 and 330R cases build on this tradition with Direct Airflow Path layouts for even better cooling and quieter operation.” Visit Corsair at Computex 2013 in Taiwan Corsair will be showcasing new products at the Grand Hyatt Taipei #2448 in Taipei from June 4-7 from the hours of 9AM-6PM.
Pricing, Availability, and Warranty
The list prices for Carbide Series Air 540 and Carbide Series 330R are $139.99 and $89.99 respectively. The cases are available now from Corsair's worldwide network of authorized distributors and resellers. Both are backed with a two year warranty and Corsair’s reknown customer service and technical support.
About Corsair
Founded in 1994, Corsair supplies high performance products purchased primarily by PC gaming enthusiasts who build their own PCs or buy pre-assembled customized systems. The company's award-winning products include DDR3 memory upgrades, mobile storage drives, power supply units, solid-state drives, PC speakers, gaming headsets, gaming keyboards, laser gaming mice, system monitoring and control devices, PC cooling products, and computer cases.
hoxlund
Legit User
Legit User
Re: Corsair Unveils Carbide Air 540 and Carbide 330R Cases
Postby hoxlund » Mon Jun 03, 2013 2:11 pm
very sexy "cube" case design. makes me miss my mountain mods u2-ufo
Corsair Obsidian 760T White
MSI X99A XPower AC LGA 2011-3 Mobo
Intel Core i7-5930K Processor @ 4.8GHz
Corsair H100i GTX Dual 120mm Radiator CPU Cooler
Klevv Cras 2800 4x4GB Memory
2x MSI R9 290X Gaming OC Video Cards
sgkean
Legit Fanatic
Legit Fanatic
Postby sgkean » Mon Jun 03, 2013 3:00 pm
The 540 has a very nice looking design, just not sure if I'm a fan of the orientation of the optical bay. Don't use a ton of discs anymore, but when I do, don't like them in that orientation. Just my opinion of course...
With the side panel being all window, would really need some good cable management to keep it cleaned up :D
Return to “Press Releases”
Who is online
