Windows 7 Secondary drive cannot boot
Operating Systems
If its an OS, its here.
BloodSkin
Legit Little One
Legit Little One
Post by BloodSkin »
SCENARIO:
Vista installed on main hdd (boot menu on this hdd)
Win7 installed on second hdd
i wish to remove he vista hdd and use only the win7 hdd but when i try to i get disk load error
FZ1
Re: Windows 7 Secondary drive cannot boot
Post by FZ1 »
Can you give a little more detail? Are you changing the BIOS settings? What is your system configuration.
Joe
DL126
Post by DL126 »
I don't think you can do what you're describing.
The boot loader that Win7 uses is located on the HDD where your initial Windows install resides.
Even though Win7 is on the 2nd drive, "part" of it is on the 1st.
Take it out, and you're removing the boot loader.
