FreeNAS
FreeNAS
I need some help with FreeNAS. I have a ISO on a DVD but my computer wont boot off of it. is there another way to boot from it?
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
Ebay is: horizonlongtails it is 100%!!!
Re: FreeNAS
Dumb questions...
1)Did you burn the ISO as a data DVD? Because you need to burn the DVD using an image file.
2)Do you have your DVD drive to boot before your hard drive(s) in the BIOS?
Re: FreeNAS
1. I had it as a data dvd, how to i burn it as a image file. i have PowerISO
2. yes dvd is first
2. yes dvd is first
Re: FreeNAS
I've been using Nero so long I don't know what the options are for PowerISO. I do know that CDBurnerXP has a menu system similar to Nero's Smartstart.
Try CDBurnerXP and burn an "Image File", I believe is what they call it. When installing CDBurnerXP watch out for the installation prompt for Ask Toolbar and it's accompanying crapware.
http://majorgeeks.com/CDBurnerXP_d4242.html
Re: FreeNAS
Thanks, do you have a link for a good download of freeNAS? so i can make sure that i have the right file.
Re: FreeNAS
I think this is the file.
http://sourceforge.net/projects/freenas/
Re: FreeNAS
Ok now I am at Console setup. what next?
Re: FreeNAS
Never installed FreeNAS but a quick search yields these results.
http://developer.novell.com/wiki/index. ... ll_FreeNAS
http://dailycupoftech.com/howto-install-freenas/
