This program is made by the people who bring us CCleaner.
Program Description:
Use Defraggler to defrag your entire hard drive, or individual files - unique in the industry. This compact and portable Windows application supports NTFS and FAT32 file systems.
v2.00.230 Changelog:
- Added offline defragmentation of system files during boot process.
- New Drive Map with custom colors and styles.
- New improved defragmentation engine.
- Improved Windows 7 compatibility.
- Lots of minor GUI improvements.
Download Links
Installer: http://download.piriform.com/dfsetup200.exe
Portable: http://www.piriform.com/defraggler/down ... wnloadfile
Screenshot
Defraggler v2.00.230 (Native x64 Included)
Re: Defraggler v2.00.230 (Native x64 Included)
How good is Defraggler compared to the one in Windows 7 and Windows XP? I thought they're all more or less the same.
Gigabyte Z77X-UD5H F14 BIOS
ASUS GTX 460 768MB @ 800/1950
Corsair AX750
Crucial M4 128GB
Western Digital Black 1TB
Cooler Master Hyper 212+ EVO
BenQ E2420HD
I AM CANADIAN!
Corsair AX750
Crucial M4 128GB
BenQ E2420HD
I AM CANADIAN!
It's faster and probably more thorough. Some defrag programs have a lot more options over the standard defrag utility in Windows, Defraggler really isn't one of them.
I have never been keen on using "outside" defraggers as i think that they are more likely to screw things up than the one in windows.
I have wanted to download one and find out weather that is the case but the PC I have for such things is not well at the moment.
Neptune24
Neptune24
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600)
Mother Board: Gigabyte GA-880GM-UD2H
BIOS: Award Modular BIOS v6.00PG
Processor: AMD PhenomII X4 965 Processor, 3.4GHz(Stock)
Memory: 16GB RAM
Graphics Card: GeForce GTX 550 Ti Memory: 1024 MB
GPU Driver: 8.17.12.7061
Direct X 11
Memory: 16GB RAM
Direct X 11
thanks for information...
Thanks for the suggestion, Major! Downed it, and am currently running it....
"Gentlemen! You can't fight in here! This is the war room!"
"Yes, very good. I'll take a bloody mary and a steak sandwich, and a steak sandwich"
ASUS M4A785TD-V//AMD Phenom II 1090T BE//Sapphire HD5770 Vapor-X//G.Skills Ripjaws 8GB DDR3 1600//Intel SSD boot//500GB & 1TB Seagate//
Antec DF85//Under Water like a scuba diver //Win 7 64-bit//
