does anyone know anyway to open a file with the attribute AE?
To make a long story short - I have a folder with encrypted files in it that were backed up. well the site my company supports decided to reinstall windows server 2003 thinking that they had backups. well during the reinstall they obviously took the encryption key with them. now they have a bunch of green files that cant be opened.. my first response was "I think you guys are SOL" but i figured I'd ask here... everything I googled if for cracking passwords - thats not really what I am lookign for here.
crack an encrypted file
Re: crack an encrypted file
Never messed with encryption... found this though..
http://technet.microsoft.com/en-us/libr ... 10%29.aspx
http://technet.microsoft.com/en-us/libr ... 10%29.aspxDecrypt a file or folder
Updated: January 21, 2005
Applies To: Windows Server 2003, Windows Server 2003 R2, Windows Server 2003 with SP1, Windows Server 2003 with SP2
To decrypt a file or folder
Open Windows Explorer.
Right-click the encrypted file or folder, and then click Properties.
On the General tab, click Advanced.
Clear the Encrypt contents to secure data check box.
Notes
To open Windows Explorer, click Start, point to All programs, point to Accessories, and then click Windows Explorer.
When you decrypt a folder, you are asked if you want all files and subfolders within the folder to be decrypted as well. If you choose to decrypt the folder only, the encrypted files and folders within the decrypted folder remain encrypted. However, new files and folder that you create within the decrypted folder will not be automatically encrypted.
Recover an encrypted file or folder without your file encryption certificate
To recover an encrypted file or folder without the file encryption certificate
Open Backup.
Use Backup to make a copy of the file in case of loss or damage.
Send the original encrypted file to the designated recovery agent.
Have the recovery agent use their recovery certificate and private key to decrypt the file.
Have the recovery agent send the decrypted file back to you, using any file transfer method that you want.
Notes
To start Backup, click Start, point to All programs, point to Accessories, point to System Tools, and then click Backup.
There is no default recovery agent on a local computer unless the computer is in an Active Directory domain environment. In an Active Directory domain environment, the administrator that initially logged on to the first domain controller is the default recovery agent.
Sending the file to the designated recovery agent can be done in a number of ways, including backing up the file to tape or floppy disk.
Files backed up using Backup or any other backup tool retain their encryption while in their backup storage location. The original files can be decrypted or modified without affecting the encrypted state of the backup copies.
You can recover an encrypted file or folder yourself if you have kept a backup copy of your file encryption certificate and private key in a .pfx file format on a floppy disk. Use the import command from Certificates in Microsoft Management Console (MMC) to import the .pfx file from the floppy disk into the Personal store.
For more information about using Certificates in MMC, see Related Topics.
-Thomas Jefferson
-Thomas Jefferson
thanks bubba- its a start..
