Build Version: HWiNFO32 & HWiNFO64 v3.93-1540 About HWiNFO:
HWiNFO™, HWiNFO32™ and HWiNFO64™ are professional hardware information and diagnostic tools supporting latest components, industry technologies and standards. These tools are designed to collect and present the maximum amount of information possible about computer's hardware which makes them suitable for users searching for driver updates, computer manufacturers, system integrators and technical experts as well. Retrieved information is presented in a logical and easily understandable form and can be exported into various types of reports.
Changelog:
Enhanced sensor monitoring on MSI MS-7585 P55-GD85, MS-7582 and Z77 series.
Added preliminary support of Coleto Creek PCH.
Added reporting of OEM Memory Information (DIMM map) under SMBIOS/DMI if supported by platform.
Enhanced sensor monitoring on ASUS P8H67-I.
Split Intel DTS temperature reporting per CPU package, added actual Core Max value.
Added recognition of nVidia Kepler: GeForce GT 640M, GT 650M, GTX 660M.
Added patch for clock measuring under Windows 8.
Changelog:
Added reporting of more Intel CPU features.
Added support of nVidia GeForce GTX 680 (GK104).
Build Version: HWiNFO32 & HWiNFO64 v3.94-1560 About HWiNFO:
Changelog:
Enhanced support of GK104 (fixed clock status, added power monitoring).
Enhanced sensor monitoring on EVGA X79 and Z77 series.
Sensor logging: value units are now displayed in the header only.
Enhanced sensor monitoring on ASUS P8B75, P8H77, P8Q77, P8Z77, MAXIMUS V, SABERTOOTH Z77 series.
Enhanced sensor monitoring on ASRock X79 and Z77 series.
Added new CPU and GPU models.
Enhanced sensor monitoring on GIGABYTE H77 and Z77 series.
Improved CPU clock measurement on Windows 8.
Fixed reporting of XMP profile #2.
Enhanced support of PMBus VRs, added new CHiL and IRF models.
Enhanced sensor monitoring on MSI MS-7737 Big Bang-XPower II.
Added support of Crystal Well.
Fixed GPU logo when switching between GPUs.
Improved GK1xx fan speed reporting.
Fixed reporting of GPU clocks for ATI R6xx family.
Added AMD Radeon HD 7420G, 7520G, 7620G, 7640G, 7660G, 7480D, 7540D, 7560D, 7660D models.
Added preliminary AMD Kaveri support.
Enhanced sensor monitoring on BIOSTAR A75 and TZ77 series.
Enhanced sensor monitoring on MSI X79 series.
Added nVidia GeForce GTX 670 and GeForce GTX 690.
Improved drive and SMART enumeration on systems with Intel Rapid Storage Technology drivers.
Fixed reporting of CPU DTS temperatures on multiple CPU packages.
Improved nVidia GPU voltage monitoring with nVidia R3xx drivers.
Added fan speed monitoring on ASUS G74Sx and G75VW notebooks.
Optimized performance and memory usage in Sensor-only mode.
Improved handling of RTSS.
Enhanced support of AMD Trinity.
Enhanced enumerating of SATA drives and respective SMART status reporting.
Improved sensor monitoring across Standby/Resume phases.
Enhanced sensor monitoring on ASUS SABERTOOTH 990FX.
Fixed missing bottom menu in sensor window on some systems with lower screen resolution.
Improved enumeration of USB ports and devices.
USB device enumeration is now attached to PCI USB Host Controllers too.
Fixed changing of values in sensor config.
Improved sensor monitoring performance on systems with Sandy Bridge and later CPUs and added reporting of PCH temperature.
Added reporting of driver information for major devices (PCI, USB, GPU, Audio, Network).
Added reporting of driver information for major devices (PCI, USB, GPU, Audio, Network). Added support of SMSC LPC47M534 sensor.
Updated SMBIOS support to v2.7.1.
Updated reporting of shader count on AMD Southern Islands and London series GPUs.
Enhanced sensor monitoring on ASUS P8H61-I.
Improved reporting of parameters on several AMD GPUs.
Added AMD Bonaire and Oland.
Added support of IRF IR3564.
Added preliminary support of AMD Mars.
Added fan speed monitoring on Clevo W860, W870, W880, P150, P170, P180.
Added preliminary support of AMD Steamroller family.
Added preliminary support of AMD Steamroller family. Fixed BSOD with certain Intel RST drivers.
Fixed BSOD with certain Intel RST drivers. Added support of IRF IR3563 Digital PWM.
Enhanced sensor monitoring on GIGABYTE Z77X-UP series.
Added nVidia Quadro K1000M, K2000M, K3000M, K4000M, K5000M.
Added nVidia GeForce GTX 650M and GeForce GTX 680M.
Enhanced sensor monitoring on ASUS MAXIMUS V EXTREME and MAXIMUS V FORMULA.
Enhanced sensor monitoring on GIGABYTE B75 series.
Enhanced support of VIA VX11 chipset.
Added nVidia GeForce GTX 660 Ti, GeForce GTX 650 and Tesla K10.
Improved enumeration of (S)ATA drives.
Enhanced sensor monitoring on ASUS P7H55-M LX.
Reduced system load during sensor monitoring via certain SIO/LPC chips.
Added preliminary support of AMD Kabini (Jaguar CPU cores).
Added AMD FirePro V3900, V4900, V5900, W600, W5000, W7000, W8000, W9000.
Enhanced GPU I2C scan on nVidia Kepler.
Enhanced support of Ivy Bridge-EX.
Added preliminary support of Haswell-EN/EP/EP 4S/EX.
Improved recognition of Sandy Bridge/Ivy Bridge CPU package.
Improved reporting of clocks on some AMD GPUs with switchable graphics.
Download pre-release: v4.03, Build 1720
Enhanced sensor monitoring on ASUS P8C WS.
Added support of On Semi ASP0800 on nVidia GPU.
