Word processor converters
My grandmother has an old E-Machines and all her word documetns are in WORKS and WORD PERFECT 5.2. I was wondering IF anyone knows of a converter I can install that would convert all of them to WORD 2000? I was just going to take her old HDD and put it in a different PC to upgrade it for her but her E-machines loaded HDD wont even boot on another system. Any ideas as to how I canget her into a new system without loosing her old word files??
Merlin
Windows 10 64 bit home on both
ASUS Z97-A LGA1150|i7 4790K|32Gb G-skill Ripjaws DDR3 2400| EVGA GTX660 | Corsair HX520W PSU
ASUS ROG MAXIMUS X HERO 1151|i7 8700K|32Gb G-skill Ripjaws DDR4-2666| EVGA GTX1080 | Samsung 500GB SSD | Corsair AX760 PSU
- Alathald
not sure if it will batch convert, but I personally use openOffice because it opens all types of document including word, wordperfect and works. It also saves in all those formats. you could try using it to convert her files or just make oO her default processor on her new machine, then there is no need to convert the files. Good Luck on updating grannys machine
I will try the open office and see. Thanks for the tips.
Merlin
