The Full Review on the Processor can be found here
After looking at the benchmarks it is clear that a 200MHz increase in the FX line boosts performance roughly 10% across the board on the majority of benchmarks used. This makes perfect sense as it truly is a 10% increase in overall frequency.
Exactly, I would like to know the time a FX-53 takes to complete a SETI WU.
I have an old system, a TYAN-Tiger 1834s Dual PIII 800mhz.
I have some tricks in order to speed up my SETI Crunching time, like using the CLI version, with it I can install two different CLI SETI Instances, one for each CPU. Also have installed Ramdisk NT in order to make the crunching at speedy RamDisk, and so on...
I have seen on internet some SETI test running on FX-51, it is able to complete a WU in just 1h 40min, thats WAY too cool...
Now, just been curious, I would like to know how the 200 Mhz increment on the CPU Clock (from FX-51 to FX-53) shows when doing a SETI WU.
