Modding my case
Modding my case
What designs dp you think would be cool cutout on my pc case? i will be cutting out a design and backing it with plexi-glass. lmk what kind of design would be cool looking on it. thanks
- Bio-Hazard
Re: Modding my case
That's prett hard to answer, just do whatever you like for a case theme. As with all mods, the only one that you need to please is yourself, if you're happy with the outcome, then all's good.
Re: Modding my case
What would probably work the best is come up with a concept and go with it. Movies, games, art, objects, hotrods, boats, motorcycles, etc. What it usually comes down to is your interests. How about a sports team logo? Do a team case design.
