Air-cooled maXior
Air-cooled maXior
DFI SLI + Opteron165@ 2.4Ghz
Asus 7800GT@495/1245 + XFX 6800GS + Corsair 2GB XMS LLPro
+ OCZ 600W + CM Stacker 15xAC +
Raptor 74GB + 2x Hitachi 160GB Sata2 + Plextor DVD-RW 16x 716A + Asus CD-R 52x
The pleasure is to listen it, not to see it.ELIK18 wrote:I LOVED THE SOUND SYSTEM
LOOK GREAT
I WANT IT!!!!
All for $4k + many hours to do it right.
OC:
AMD Opteron 1.8GHz dual core @ 2620MHz max with AC,
usually 2.4GHz with 1:1 Corsair 2GB XMS 3500LL Pro 2-3-2-6 418MHz @ 540 DDR 3-4-4-8. Timings set only once. I'm going to tight them in 2 days when I have some free time.
Asus 7800GT 400/1000 @ 510/1245 - 2 weeks ago I broke some coil on it = RMA
Instead for those days I use XFX 6800GS 350/1100 without OC.
T proc = 26^C idle
= max 32^C in games, compression etc
= "non stop" 7 days 32-36^C
T card = 33^C idle
= max 35^C in games
T nb = max 33^C
T pwmic = 30-34^C
T surroundings/in case = 24^C
V cpu = 1.45V (1.5-1.525 set in bios) //can be lower//
V dram = 2.7 //can be lower//
I need some time to set up timings!
T memory coolers = cold
T proc radiator = lightly cold
T drives = cold
T room = cold when PC on, cool without!
my 7800GT mod
- Dragon_Cooler
My idea was to buy 4x Geil 512MB 2-2-2-5, 182$ each. But 4x are less want to @ than 2x , so I stayed with 2x.Dragon_Cooler wrote:a few things....
LOOKS GREAT!!!!
What was the point in gettting led ram if you cant see it through the fans. LOL
What happens if something falls in your case right into the screaming fans of death, especially with your 200mps tape!!
Again nice i like it!!!!
I've bought 2x Geils at Newegg.
After 5 days I've got Corsairs 2GB XMS 3500LLPro.
Who wants to send it back?
hehhehehe
I played Battlefield2 and used 777MB of memory, so I'm sticking with it!
LED?
It's cool, right, but what else?
After 2 months of rainbow I decided to overclock my memory, too.
I think tighten timings and more bandwidh will definetely bring more heat.
Now their coolers are really cold and i think it's quite cool.
Nothing can fall !!!
I spent more than 100hours just to check that every fan is in right place nad what to do more to make it better with only AC.
Plans:
1)14th March = dentist, 550$
2)1st April = flight to Arizona clubs for a weekend
3)any other day in between = buying AsetekWC for $470
4)as soon as possible = buying 10feet 14 gauge really good speaker wire $50 and Creative Labs X-Fi Platinum
Do You believe that I'm in love with the sound by using "sound on the board" ?
ok, what means 200mps tape?
I don't know do You see it, but every fan has its own control.
They go through the last PCI slot out. I'm gonna build some control set under my table for them but stilll, I need some more spare time.
Fans:
3x120 down
2x120 front
1x120 back up
2x80 back down
1x90 up
1x120 processor + Thermalright XP 120 cooler
2x90 memory
1x80 back of graphic card + Zalman 770Cu 1x90mm
1xNB cooler (the biggest I found)
You can add 3 more or even 6 more after I buy Asetek radiator to lower the temperature of water!!!
but still, it's great to change anything, it's the feeling of joy when it works and works just fine or even better than before
LOve it!
- Dragon_Cooler
