I guess this should go here, since it's modding.
Anyway, I have an old laptop that I'd like to integrate a small 4 port usb 2.0 hub into (not through a pcmcia card, though). I have a spot to put it, the only problem is power. Would it be possible to build a small regulator box or whatever, that would take the voltage from the wall, and then step it down on two circuits, one for the laptop, and the other for the hub, all through the same ac plug?
In my mind, it would kinda look like this:
The plug is the +, the wires are the lines, and the transformer box is the two [-]'s.
I know this seems ambitious, but if I get the right resistors and what not, it should be possible. Any thoughts?
P.S. I have to get a self-powered hub, not a usb powered hub, as the laptop only has usb 1.1 in it.
Hacked power adapter
- The Black Pumpkin
AMD Opteron 1224SE "Santa Ana" = DFI Lanparty UT NF590 SLI-M2R/G
Crucial Ballistix 4x1GB DDR2 800 = Corsair CMPSU-750TX
Sapphire 4870 1GB = Sceptre X20WG-Naga 20" = Logitech X-530 5.1
Seagate 320GB (SATA II) x2 = Samsung SH-S203B (SATA)
- The Black Pumpkin
Heh, nevermind, I just found this, which shows it's possible. I just need to get one and modify it a bit, and presto!
- The Black Pumpkin
And this whole project has gone down the tubes, since I'll just get a pcmcia card if I need more than one usb port at a time. It's just too hard to hack into power sources internally in laptops.
