Hi guys, I finally got my watercooler going with no leeks not bad for first timer with watercooling if I say so for my self. I used Enzotech water block http://www.newegg.com/Product/Product.a ... 6835708019 , Swiftech radiader with 2 Cooler Master 120mm red LED fans, Thermaltake aquabaf M5 http://www.thermaltakeusa.com/Product.a ... 62&ID=1638 , Feser one F1 cooling fluid with Feser one VS.C fluid, 3/8 ID x 1/2 OD tubing.
Click on the pic to get full size.
Got my watercooler going
Re: Got my watercooler going
And the results?
Runs rely good, my temps are in the high 20s. that's all most a 10-12c drop from were it was.
This load or idle? Were you able to clock your CPU faster?
- dicecca112
- Site Admin
Watch out for the Feser blue, its known to congeal (if that's spelled right) and clog waterblocks.
Idle, load is about the mid to high 40s most of the time and the highest I seen it at was 50c I think. Right now I have it at 3315Mhz, I know I can get it at 3.5 was that was on air, but I want to go 4.0 so I can get a suicide screenshot for another forum and to say I got it there, but I'm having a little problem doing it.Major_A wrote:This load or idle? Were you able to clock your CPU faster?
I'm using purple, it's mixed with Feser VS.C . I'm glad I didn't go with the blue.dicecca112 wrote:Watch out for the Feser blue, its known to congeal (if that's spelled right) and clog waterblocks.
