Hi guys.
First that all, i'm new here and i hope learn a lot here.
It's was wonder if you guys can help me to take a final component to buy.
I found the HAF X in my country for a decent price, even, I did a "pre-paid" for it until get the total money for it (1 or 2 weeks).
My current case is a Thermaltake V9 (specs here) but my GPU (GTX 260) is out date now. My question is, should I go with the case and change the GPU later? or change the GPU now and wait for change the case.
I was thinking in go with the case and wait for the GTX 590 release, maybe the price drop a little and then get a GTX 560 Ti or something better.
What do you think? What would you do?
I'm not a hard core gamer, not a big fan of run games with all at max setting or things like that. I mostly play FPS and multiplier games at 1920x1080 without AA or any of those options enable.
Thanks for your help on this.
What to do? New case or new GPU
saint19
Re: What to do? New case or new GPU
for what you said your needs are I'd say stick with the card you have, and get the case. Personally though I am not a real big fan on spending more that $50 on a case, so I will always upgrade a GPU over case.
I would go for the GPU upgrade if it will be a huge bump in performance. Are the games you play now running poorly with the GTX 260?
What's the rest of your hardware like? Getting a GTX 560 or 590 doesn't make sense if you don't have a fast CPU to back it up.
