Budget Mid Tower or Smaller Case with good cooling and quiet
BrightSide
Legit Enthusiast
Legit Enthusiast
Post by BrightSide »
I need to get a couple of bargain cases for my office, and was wondering what you guys think about Rosewill's Redbone, Line Glow, etc... Budget cases. Also, other suggestions welcome for Cases around or under the $30 Mark. Thanks.
walterm
Legit User
Legit User
Re: Budget Mid Tower or Smaller Case with good cooling and q
Post by walterm »
I've built with the Redbone (which is pretty much a bottom mount power supply version of the Blackbone), and it is a very good case when on sale. Also have built with the Ranger-M mATX case, good but a bit tighter (hidden cost, I usually swap 80mm rear fan for a 92mm one). I've has a Challenger build for many years (poorer wire management by todays standards).
To be serious need to know intended hardware inside. Though I expect you've already purchased your choice.
The Redbone would be an Excellent build.
