My HP w120 4GB pen drive refused to be format and some mp3 files on it became write protected files
I tried virus scan, stop it from auto run on xp, setting the file property but nothing work
so I tried to get it back to work with my Ubuntu "testdisk" programe, still there is no luck.
Since a computer noob like me do not understand what the testdisk log tell me about my poor little pen drive
Doctor please help me find out if it is dead, or is there a remedy to save my pen drive , I knew a pen drive is cheap but
I do not want to throw it away if it can be fixed, Mr Earth is very sick now, one more false pen drive rubbish is too many.
Doctor please help Thank you very much for your time, the log is a bit long
below is the log of the testdisk:
Fri Mar 13 12:58:18 2009
Command line: TestDisk
TestDisk 6.9, Data Recovery Utility, February 2008
Christophe GRENIER <[email protected]>
http://www.cgsecurity.org
Linux version (ext2fs lib: 1.41.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none)
Hard disk list
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ATA ST3160811AS
Disk /dev/sdb - 81 GB / 76 GiB - CHS 9964 255 63, sector size=512 - ATA Maxtor 6L080M0
Disk /dev/sdc - 4043 MB / 3855 MiB - CHS 1018 125 62, sector size=512 - HP v120w
Disk /dev/sdc - 4043 MB / 3855 MiB - HP v120w
Partition table type: Intel
Partition table has been cleared.
You have to reboot for the change to take effect.
A new copy of MBR code has been written.
Analyse Disk /dev/sdc - 4043 MB / 3855 MiB - CHS 1018 125 62
Current partition structure:
No partition is bootable
Ask the user for vista mode
Allow partial last cylinder : No
search_vista_part: 0
search_part()
Results
interface_write()
No partition found or selected for recovery
search_part()
FAT32 at 0/0/7
FAT1 : 32-995
FAT2 : 996-1959
start_rootdir : 1960 root cluster : 2
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
no_of_cluster : 123361 (2 - 123362)
fat_length 964 calculated 964
FAT differs, FAT sectors=952-960/964
heads/cylinder 0 (FAT) != 125 (HD)
sect/track 0 (FAT) != 62 (HD)
FAT32 at 0/0/7
D FAT32 0 0 1 1018 122 23 7897087 [HOPPY LABEL]
FAT found using backup sector!, 4043 MB / 3855 MiB
Partition not added.
Results
interface_write()
simulate write!
write_mbr_i386: starting...
write_all_log_i386: starting...
No extended partition
Interface Advanced
New geometry
Disk /dev/sdc - 4039 MB / 3852 MiB - CHS 1018 125 62 sector_size=512
Interface Advanced
file_read(6,16,buffer,0(0/0/1)) read err: Input/output error
Analyse Disk /dev/sdc - 4039 MB / 3852 MiB - CHS 1018 125 62
Partition: Read error
search_part()
Results
interface_write()
search_part()
file_read(6,16,buffer,6(0/0/7)) read err: Input/output error
Results
interface_write()
simulate write!
Store new MBR code
New geometry
Disk /dev/sdc - 4040 MB / 3852 MiB - CHS 1002 125 63 sector_size=512
Analyse Disk /dev/sdc - 4040 MB / 3852 MiB - CHS 1002 125 63
search_part()
Results
Change partition type:
D No partition 1001 0 1 1001 124 63 7875
interface_write()
simulate write!
Store new MBR code
Interface Advanced
Disk /dev/sdc - 4040 MB / 3852 MiB - HP v120w
Interface Advanced
search_part()
Results
D FAT32 0 0 1 1001 124 63 7890750
interface_write()
search_part()
FAT32 at 0/0/7
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
sect/track 0 (FAT) != 63 (HD)
FAT32 at 0/0/7
D FAT32 0 0 1 1002 100 37 7897087 [HOPPY LABEL]
Results
Can't open backup.log file: No such file or directory
interface_load
D FAT32 1001 124 63 1001 124 63 1
interface_write()
simulate write!
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/1
FAT32 at 0/0/1
Info: size boot_sector 7897087, partition 7897087
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
P FAT32 0 0 1 1018 122 23 7897087 [HOPPY LABEL]
FAT32, 4043 MB / 3855 MiB
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/1
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
Warning: Incorrect number of heads/cylinder 0 (FAT) != 125 (HD)
Warning: Incorrect number of sectors per track 0 (FAT) != 62 (HD)
search_part()
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/1
Results
interface_write()
Write isn't available because the partition table type "None" has been selected.
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/1
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
search_part()
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/1
Results
interface_write()
search_part()
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/1
FAT32 at 0/0/7
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/7
set_FAT_info: name from BS used
D FAT32 0 0 7 1018 122 29 7897087 [HOPPY LABEL]
This partition ends after the disk limits. (start=6, size=7897087, end=7897092, disk end=7897087)
Search for partition aborted
Check the harddisk size: HD jumpers settings, BIOS detection...
The harddisk (4043 MB / 3855 MiB) seems too small! (< 4043 MB / 3856 MiB)
The following partition can't be recovered:
Results
interface_write()
New options :
Dump : Yes
Cylinder boundary : Head boundary only
Allow partial last cylinder : Yes
Expert mode : Yes
Computes LBA from CHS for Disk /dev/sdc - 4043 MB / 3856 MiB - CHS 1019 125 62
Interface Advanced
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/1
FAT32 at 0/0/1
Info: size boot_sector 7897087, partition 7897250
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
P FAT32 0 0 1 1018 124 62 7897250 [HOPPY LABEL]
FAT32, 4043 MB / 3856 MiB
fat32_boot_sector
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
FAT32 at 0/0/1
FAT1 : 32-995
FAT2 : 996-1959
Data : 1960-7897063
sectors : 7897087
cluster_size : 64
Boot sector
OK
Backup boot sector
OK
Doctor , Is my Poor little USB Pen drive certified??
Re: Doctor , Is my Poor little USB Pen drive certified??
Try burning Gparted to a CD and boot from it with your USB device plugged in.
Try formatting the USB stick, with that program.
Dan
Dan
I used Gparted but it show the usb drive as unallocated disk and it cannot format it
It's been my experience that if gparted can't help you then the drive is very poorly. (You might have to throw this one away after all)
Dan
Dan
Thank you for your time. I would have to let go this poor pen drive. Rest in peace my little Hp pen drive.
- Alathald
I've had a couple of pen drives that I thought were fubar (did the same thing as yours in gparted) that I managed to save but I'll be damned if I remember how...I think I had used the dd command to basically force it to wipe and partition the drive. I'll do some looking and see if I can recall how I did it. Then again, it could just be a dead drive.
Warning though, if there is one command that could destroy the world, it would be dd...or maybe "import skynet"
