SRT? Is it with it?
Skippman
SRT? Is it with it?
Post by Skippman »
I'm in the process or rebuild my rig and the only differences I can see between the P67 and Z68 are the intergrated GPU and the SRT. I'm not to excites by the onboard GPU thing and like some of the P67 boards better but SRT intrigues me.
Is it worth it even if I use a cheap $70 SSD? Can I use SRT with two HDs in RAID 0?
Major_A
Re: SRT? Is it with it?
Post by Major_A »
Gigabyte has a board with a built-in SSD.
http://www.legitreviews.com/article/1677/1/
I don't see why it wouldn't work in RAID. But you might want to wait for a confirmed yes or no.
SRT is for those that don't want to re-configure windows on an SSD.
If you're going to buy an SSD then you might as well put the OS on there. It will be faster than Intel SRT anyway... It's a pointless feature if you ask me.
Skippman
Post by Skippman »
Well, I'm not planning on dropping $200 for a large SSD. So you think it's not worth it? I guess that opens up a whole list of motherboards for me then as that was the only real feature to the Z68 chipset other than the GPU which I don't want anyway.
Major_A
Post by Major_A »
If you can use Intel's Quick Sync then you would want use the on-die GPU. That said I think to use it in conjunction with add-on GPUs the board has to have a Lucid Virtu logic on the board.
Quick Sync Examples:
http://www.guru3d.com/article/core-i5-2 ... -review/15
http://www.legitreviews.com/article/1649/6/
http://www.anandtech.com/show/4083/the- ... 0-tested/9
Lucid Virtu:
http://www.lucidlogix.com/product-virtu.html
pwcmed
Post by pwcmed »
Like Nate said, I saw no real value in SRT. If I need to upgrade from a HDD to a SSD I would just reload windows. I went from a ATI 5970 to a Nvidia 580 and lost that third monitor option. The Z68 helped give the third monitor back. I cant game on it but I can still use it, man I really miss eyefinity.
I have an Asus board lying around, let me know if you're interested.
http://www.newegg.com/Product/Product.a ... 6813131708
Major_A
Post by Major_A »
Here's a review from today using Virtu.
http://www.overclockersclub.com/reviews ... dup/20.htm
