GTX 460 temps
skier
GTX 460 temps
Post by skier »
so i got myself a new GTX 460 from EVGA a little before christmas and finally put my old 460's Arctic freezer pro dual fan heatsink on it (below)
now these are my temps after running Furmark 1.8.2 with postFX and extremeburn at 1920x1080 for about 15minutes while i was putting my xmas tree away
is that (93c) reasonable? been a long time since i had my old 460, and 70% is the point where i start to actually hear the AC FreezerPro louder than the other fans
-Austin
Screamin' BCLK: Image
Major_A
Re: GTX 460 temps
Post by Major_A »
It's my understanding there's a software switch in the nVidia drivers that notices the FurMark executable. From there it locks the temp down to a certain temp/voltage. Try running a different 3D demo and seeing what the temps are. Realistically FurMark is more demanding than any game on the market so it's a pretty bad indication (IMHO) of temps.
Loop Unigine Heaven for the 2 or 3 runs with all the details turned up and see what's reported. Even a better indication would be a loop it at the resolution you play your games at and where the benchmark is still smooth. You aren't going to play Battlefield 3 if it looks like a slideshow. That make sense?
sbohdan
Re: GTX 460 temps
Post by sbohdan »
93C would be to much even with the stock cooling, not alone that cooler. Something is definitely wrong here furmark or not. Maybe the cooler is not installed correctly or you forgot to put some paste on the core :lol:
Take the cooler off and check everything again.
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte B550 Aorus Elite, Ryzen 5800X @ stock, 32GB Patriot Viper DDR4 3200Mhz 16-18-18-36-1T, AMD RX 5700XT + AlphaCool WC, ACER Nitro XV2 27", SP 1TB nvme PCiE GEN3, Samsung 2TB; Cooler Master MW Gold 650W, Win10 Pro 64
skier
Re: GTX 460 temps
Post by skier »
just finally ran metro 2033 for a bit to test temps, steady 51C with the settings cranked. didn't think furmark was that far off, still good to test stability tho!
-Austin
Major_A
Re: GTX 460 temps
Post by Major_A »
Sounds more like the temps you'll actually see playing games.
Sent from my PC36100 using Tapatalk
skier
Re: GTX 460 temps
Post by skier »
i didnt notice this with my previous 460, but furmark 1.7.0 mode at 1920x1080 at 900/2050 is only running at a steady 55c, whereas 1.8.2 mode cranked at lower clocks was hitting north of 90C. must be a glitch in furmark, i remember my gtx 260 couldn't even RUN 1.8.2 mode
-Austin
vbironchef
Re: GTX 460 temps
Post by vbironchef »
F@H is a good way to test temps Hint, hint!
skier
Re: GTX 460 temps
Post by skier »
vbironchef wrote:F@H is a good way to test temps Hint, hint!
53c @870/1738 /1850 8)
-Austin
