These are the prices you will get if your local CompUSA has them in stock!
THe sale is this week only and works on jsut PNY cards.
6800 - $299 = $209.30
6800 GT - $399 = $279.30
6800 Ultra - $499 = $349.30
Don't forget local taxes since this is a B&M deal.
PNY 6800, 6800GT, 6800Ultra all 30% off @ CompUSA
- Apoptosis
- Site Admin
For PNY Card Info: http://www.pny.com/products/verto/
As for the main differences...
The 6800 Ultra:
Memory Interface 256-bit
Memory Bandwidth 35.2 GB/sec.
Fill Rate 6.4 billion texels/sec.
Vertices per Second 600 Million
Core clock: 400MHz
Memory Clock: 1.1 GHz
Pixels per Clock (peak) 16
Textures per Pixel* 16
Dual RAMDACs 400 MHz
The 6800 GT:
Memory Bandwidth 32 GB/sec.
Fill Rate 5.6 billion texels/sec.
Vertices per Second 525 Million
Core clock: 350MHz
Memory Clock: 1GHz
The 6800:
Memory Bandwidth 22.4 GB/sec.
Fill Rate 3.9 billion texels/sec.
Vertices per Second 406 Million
Core clock: 325MHz
Memory Clock: 700 MHz
Pixels per Clock (peak) 12
The 6800 only has 12 pixles per clock and 700MHz memory... Both the DT and Ultra are 16 pixels per clock and use 1GHz+ DDR3 memory for more memory bandwidth and greater performance. The GT is the best bang for your buck card and is said to OC easily to "Ultra" levels.
The 6800 Ultra:
Core clock: 400MHz
The 6800 GT:
Core clock: 350MHz
Memory Clock: 1GHz
The 6800:
Core clock: 325MHz
