My New Video Card for My New Build Should Be....?
Howdy, all.
I need some suggestions for a video card for my new build. I have had good success with nVidia and would like to stay with them. Here are the stats:
I am a weekend warrior (well, shaman actually) gamer. I play WoW, EQII, and the occasional PC game like Roller Coaster Tycoon or Hello, Kit... um... other similar games. I also use my computer heavily for a blog I maintain and for word processing and photo editing.
At the current time, I have the following components for my new build
Motherboard: Intel D975XBX2
Processor: Intel Core 2 Duo P6400 Conroe 2.13 GHz 775
RAM: 2 GBs of Corsair DDR SDRAM 800 Dual Channel
OS: MS Vista Ultimate - 32 bit
I have been looking at one card that has piqued my interest, but it might be overkill: GeForce 8800GTS 320 MB GDDR3
DirectX 10 would be nice, but I don't think essential for my usage.
Any thoughts? Suggestions?
Best wishes,
Seth
Best wishes,
Seth
- Sparky
My last 3 cards have been EVGA. Lifetime warranty and 90 day step up program to trade up. Current card was the result of a step up from 7950 GT KO 512mb to 8800 GTS 640mb and the cost was only $160.
I got the eVGA 8800 gts a few weeks ago and I like it alot. I had a eVGA 6800. I play BF2142 on highest settings and I get per Fraps a minimum of 56+fps at all times playing. In my Full Armor I can not heard it over the two 120mm fans with the case. You should have two spare power connectors for it..as my PSU is SLi compliant I had them. I also had plenty of space on my ASUS A8N preminum too. I have to get power connector leads (extension) so I can dress out the power cable..which I don't like the way they are now and are not out of the way of the air flow like I like it. I say go for it if you have the ~$300US for it.
WOW will look alot better and you can use the dual output to drive a LCD/CRT and a large screen 50" for photo slide shows or powerpoints which I do.
- Alathald
I highly reccomend the 8800GTS 320MB...I got the extreme XXX version from XFX because I plan to OC it farther in the future but even at stock setting, this card more than made the soft blow to my wallet well worth it.
Also, unless I've REALLY overlooked something (I don't think I have), the 320MB edition only needs one 6pin power connector...
Currently this looks like the best card for the money and if you're willing to spend it, you'll be glad you did.
- DaddyRabbit
All the GTS cards only use one PCI-E power connector (I have the 640mb version) the GTX requires two.Alathald wrote:I highly reccomend the 8800GTS 320MB...I got the extreme XXX version from XFX because I plan to OC it farther in the future but even at stock setting, this card more than made the soft blow to my wallet well worth it.
The GTS320 would be a good buy as long as you don't have to give blood and sell the dog to get it
It may be overkill for the moment but in a year you'll be glad you did methinks
Asrock Z68 Extreme4 Gen3
Core i7 2600k
Corsair H100 Liquid Cooler
8gig (2x4) G.Skill Ripjaws DDR3-1600
Powercolor HD5870 PCS+
OCZ Agility 2 240G SSD (boot, programs, games)
WD Caviar Black 1TB (Data)
CM UCP RS700-AAAAA3 700W 80+ Silver PSU
CM Storm Sniper
Gateway FHD2400
Win 7 Pro 64bit
Core i7 2600k
CM Storm Sniper
Gateway FHD2400
Win 7 Pro 64bit
- stopthekilling77
hey! i'm glad that everyone is pointing you in a higher-end direction BUT you might want to check this midrange card (retails at ~$100) and LR just did a review on it.
eVGA GeForce 7600 GS 512MB Video Card
can't really hurt to read a review right? hahaha but the 8800 GTS you were looking at really is a sweet card, too - if you want to fork over the $$ for it
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
Great stuff! Thanks!
Thanks to everyone for chiming in on this. I am not too concerned about the extra dollars for the 8800, but just wondering what people in general thought.
It looks like a monster, but should do well. Hopefully a price reduction in the very near future.
I'd say unless you are looking to directx10 games, just go for a 7600GT, or a 7900gs. both are great for the games you listed. By the sounds of it the power of an 8800GTS would be wasted on those games.
However in a year or so you most likely will be regretting the 7600GT or 7900GS. it all depends on how much you are willing to spend. 7 series will be great for another year, or two years at the most, but the 8800GTS will be good for say 4 years or more.
what ever you choose, enjoy your new card!
There's a deal on a Evga 8800gts/640mb @ Buy.com w/rebate and another 7% off coupon link .
Card here : http://www.buy.com/prod/evga-geforce-88 ... 44496.html
7% OFF here : http://www.buy.com/retail/coupon.asp?pr ... caid=17581
Making a nice deal altogether (about $300)
or
This deal @ ZZF : http://www.zipzoomfly.com/jsp/ProductDe ... 39&ps=hot0
For that end price I'd go for the 8800GTS/640mb and definitly be future proof for quite awhile . :D
or
* i7 5930K @ 4GHz 1.085v - Corsair H100i GTX - Asrock x99 OC Formula 3.1
* Sandisk Extreme Pro 480gb - HGST NAS 3TB - 2x WD Blue 1TB - 32gig Crucial 2133 - EVGA 980 Ti Classified - Corsair 780T/Seasonic 760 Platinum
* LG 34" Ultra Wide - Hanns-G HZ281HPB 27.5" - LG WH16NS40 Blu Burner - SoundBlaster Z - Klipsch 4.1's/Altec center channel
* Windows 8.1 Pro/Windows 10
* Retired game rig i7 920 @ 3.9 - EVGA x58 - still going strong!
Heatware
Heatware
