Thermaltake Soprano RS101 Black Mid-Tower ATX Case
With this Mid-Tower ATX Case from Thermaltake, you can ensure reliable support to all of your needed hardware components as you build your computer. This black Soprano case can accommodate an ATX or Micro ATX motherboard and allows mounting of up to seven peripheral devices on its 7x expansion slots. This mid-tower case also ensures amazing cooling performance as it comes equipped with a 120mm fan for optimized airflow. Its front USB and audio ports allow users to hook up USB and audio devices to the computer in no time. And with its 4x External 5.25", 2x External 3.5", and 5x internal 3.5" Drive Bays, you can easily accommodate lots of storage devices or optical drives without worries. Order your Soprano ATX case today.
What It Is And Why You Need It:
Black Mid-Tower ATX Case; comes in a steel ATX case which is perfect for ATX or Micro ATX motherboard
7x expansion slots; allows hassle-free installation of additional hardware
120mm fan; ensures fast heat dissipation
4x External 5.25", 2x External 3.5", and 5x internal 3.5" Drive Bays; lets you install multiple storage devices or optical drives
Front USB and audio ports; provides convenient USB or audio device connectivity
Thermaltake Soprano RS101 Mid-Tower Case - $19 AR
- Apoptosis
- Site Admin
TigerDirect.com has Thermaltake Soprano RS101 Black Mid-Tower ATX Case with Clear Side, Front USB and Audio Ports (VG7000BWS) for $29.99 - $20 rebate = $9.99. Shipping starts at around $9 and varies by zip code.
