ATI USB TV Wonder 1.1
HI, this is my first post here, it was pure luck that I came across a forum where maybe I could get some info with other ATI USB TV Wonder unit owners. It is not the 2.0 version that I have. ATI refuses to help answer just one simple question if the product is discontinued..which I can see up to a point...but then what is one suppose to do with a unit that is working perfectly for my satisfaction? My problem only, is a sequence that I had never used before on this unit. Its called "Still Gallery". The menu shows the setup for it and I followed it many times without any luck. I can never see the box that is suppose to appear where I can store capture shots and change formats. I have no idea if its the way my actual setup with my tv and vcr and directv. I have a choice of s-video, composite and cable. I tried all three and still cannot get "Still Gallery" to appear. Is there anyone here that still has this external unit and have an answer? Thanks
- infinitevalence
ATI USB TV Woner 1.1
Maybe I might be able to get some more suggestions if I say that I've been tweaking the system and now I can capture video ...but only 50% of the time. This unit gives you a tv display where you watch tv obviously. It also has an icon button for recording video, and a capture button. This is the one that I am having the problem with. The manual says you can capture from live tv...stills. Now when i open the File player, which also has the capture button, it works just fine. Why won't it work with the tv supply and yet it does for the file player. If it were not capable to do so, then that capture button would not be there or the manual would not mention it.
