What memory should i buy o.O
maj0r_pawnage
Post by maj0r_pawnage »
Last edited by maj0r_pawnage on Sun May 27, 2007 11:08 am, edited 2 times in total.
E6300 @ 3.51GHz 1.392v
Asus Maximus Formula
Antec 550Watt Psu
Mushkin DDR-1206@ 5-5-5-15 / 2.28v
Zalman CPU Cooler CNPS7700
6408800GTS(OC 691MHz Core/2.132GHz Mem)
2x80mm case fans +2x120mm case fans
trick question! Both are the same kit!
maj0r_pawnage
whoops lol
Antec 550Watt Psu
kenc51
Post by kenc51 »
I'd go for the PC6400 kit, it will work well with your board when running 1:1.
maj0r_pawnage
interesting, how so?
Antec 550Watt Psu
kenc51
Post by kenc51 »
maj0r_pawnage wrote:interesting, how so?
The 975X board doesn't do much over 400MHz... on average, so if your running 1:1 then the ram will be somewhere between 800 and 900MHz.
Most, if not all PC6400 kits can do that!
If you got the PC1066 kit, your board would have to run a FSB of over 500MHz and the 975X chipset can't do that without a few voltage mods.
Don't bother running anything else than 1:1 with a lower end C2D as your need some very fast ram and the performance increase is negligible...
maj0r_pawnage
so the new ram wont get me more than 140mhz? i had it running at 400fsb with my 5400 kit so shouldnt i be able to get atleast 3GHz with the dominators?
Antec 550Watt Psu
kenc51
Post by kenc51 »
You'll need to hit ~429MHz fsb to hit 3GHz, that's also about the max the 975X chipset does too! (Some do more, but afaik not much more)
maj0r_pawnage
whats the limiting factor on the 975x boards?
Antec 550Watt Psu
kenc51
Post by kenc51 »
maj0r_pawnage wrote:whats the limiting factor on the 975x boards?
The 975X chipset :shock:
JohntechUPi
Legit Aficionado
Legit Aficionado
Post by JohntechUPi »
I have tested a lot of I975 and I965 MB's and all of them top out about 900-980 MHz for I975 and 940-1030 for I965 with out over volting the chipset and memory, you also need to choose a MB that gives you options to over clock like ABit, ASUS, MSI, or Giga-Byte or the Intel Bad Axe 2 only.
