hmmm both 2x 1Gb kits are $109.99 at the egg,
gskill timings: 4-4-4-12
http://www.newegg.com/Product/Product.a ... 6820231065
mushkin: 4-5-4-11
http://www.newegg.com/Product/Product.a ... 6820146673
both are at a great price, and i might just be able to put my new pc together within a few weeks... not too sure on which is the slightly better timing, but
tough call, any suggestions?
same price: mushkin or g-skill?
- stopthekilling77
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
- stopthekilling77
quite true! amazing the things you gloss over when you're just looking.... apparently they're the famed Micron D9 chips too...
i'll leave this up for the sake of the poll, i've still got a little bit to wait before i can buy these suckers though
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
- JohntechUPi
- Legit Aficionado
Personally looks are not the only thing to consider, I would go Mushkin over G-Skill hands down. If you have a problem with G-Skill who will replace them? Mushkin has in the past been great about replacing failed modules.
However, I will only use Corsair any more.
One-liner about business
Producing a system from a specification is like walking on water; it's easier if it's frozen.
you should take a look at these they are $144.00 but much better memory
Micron D9. this is the kit I run and can tell you they overclock very well.
http://www.newegg.com/Product/Product.a ... 6820146108
* CPU: Q6600
* HSF: Enzotech Ultra-X
* MB: Intel D975XBX2
* RAM: (2X2GB) Mushkin XP2-8500
* VGA: Evga GeForce 8800GS
* HD1: WD Raptor 36GB
* HD2: Seagate 7200.10 (320GB)
* HD3: WD 640GB AAKS
* PSU: Corsair HX620W
* Case: Lian-Li PC- A16, modified
* LCD: 24"Gateway FHD2400
* OS: Windows XP Pro.
- JohntechUPi
- Legit Aficionado
Or these $91.00 after $40.00 Mail-In Rebate
http://www.newegg.com/Product/Product.a ... 6820145034
Or these which are Micron D-9 $153.00 after $40.00 Mail-In Rebate
http://www.newegg.com/Product/Product.a ... 6820145043
