memory prob (i think)
Hey, I got some problems with my PC and i think it's memory related.
For example, when using a Video Editing Program and trying to Render something that is high resolution, it takes way too long, few friends have tried it and it's ok for them.
Here's an avi I tried to make - http://rapidshare.com/files/53443024/church.avi.html
There shouldn't be any glow in it at all.
http://img525.imageshack.us/img525/6610/gggggnx8.jpg - it shouldn't take that long at all, should take about 5 minutes max
Don't know if it's related or not but sometimes in Adobe Photoshop too, when I keep copy and pasting, it becomes slower and slower each time and I have to reopen the program for it to be ok again.
Checked for viruses and spyware using Ad-Aware, Spyware Doctor, Spybot, Avast Antivirus and AVG and also tried reinstalling the plugin and Vegas but still get the problem.
My specs:
(CPU) Intel® Pentium® 4 CPU 3.20GHz @ 3192MHz (Dell Inc. 0GC375 mainboard)
(RAM) 1GB, 423.35MB free
(HDDs) 530GB, 59.7GB free
(VGA1) NVIDIA GeForce 6800 (256MB), 1280x1024x32, 85Hz
(OS) Microsoft Windows XP Home Edition (SP2)
Any ideas how I can fix this?
My specs:
- kenc51
Re: memory prob (i think)
I don't think it's faulty ram but you should run memtest to be sure.
how I do that?
Just to point out that it's fine with a 800x512 avi but messed up with a 1280x720 one.
Could be that you are running out of free memory? Check task manager to see your free RAM when running the encoding.rayjay wrote:Just to point out that it's fine with a 800x512 avi but messed up with a 1280x720 one.
Memtest can be found here. Burn the ISO to a CD and boot from the CD to run it.
Dan
well my floppy and cd rom drive don't work so i can't do that
in task manager, mem usage for the program is 70k, cpu usage varies from 50-60% and PF uage is about 700mb
Well that checks out.
If your PC supports booting from a USB drive you can run memtest from one of those.
Dan
Dan
- kenc51
There's also windows memtest
http://hcidesign.com/memtest/
run two instances so all your ram is tested, leave it to run for a few hours
done it, 0 errors it said
- kenc51
Am I reading the screenshot correctly, you're trying to encode ~51mins ~22sec of HD content? this will take a long time on a P4
nah, it was taking too long to render, anyways fixed it now, just updated the gfx drivers lol
