?? Will "Too Much" Memory Degrade Performance ??
tlbaxter
Legit User
Legit User
Post by tlbaxter »
Hello once more,
As I mentioned in a previous post I am planning to install 8GB and run Vista-64 (actually, Server 2008).
I'm hesitating on the 8GB now because I read on a couple other sites that "too much" memory can actually slow down a system. Can this be true and if so, under what circumstances might it be true?
Thanks much.
maj0r_pawnage
Re: ?? Will "Too Much" Memory Degrade Performance ??
Post by maj0r_pawnage »
no it won't, it will just be unused if there is excess
E6300 @ 3.51GHz 1.392v
Asus Maximus Formula
Antec 550Watt Psu
Mushkin DDR-1206@ 5-5-5-15 / 2.28v
Zalman CPU Cooler CNPS7700
6408800GTS(OC 691MHz Core/2.132GHz Mem)
2x80mm case fans +2x120mm case fans
vicaphit
Post by vicaphit »
What do you plan to do with all of that memory? Unless you are doing some serious multi-tasking you are likely going to have much of it sit unused. And by most I mean 4 gigs of memory sitting there doing nothing.
Andy
PSN: VICaphit
ibleet
Post by ibleet »
Too much memory shouldn't degrade performance, but it is pulling voltage.
Anything over 4Gb ram is overkill for the average user. What do you plan on running that requires 8Gb ram?
tlbaxter
Legit User
Legit User
Post by tlbaxter »
I plan to use the machine as a Vista-64 test development machine as well as a SQL Server/Windows Server 2008.
I know it's probably overkill but God I just want it! May the OS never have to page again.
Thanks to everyone for the responses.
tormentor
Legit Enthusiast
Legit Enthusiast
Post by tormentor »
i think this article from THG got the answer for ure q
http://www.tomshardware.com/reviews/vis ... ,1775.html
hope ull find it helpfull
tlbaxter
Legit User
Legit User
Post by tlbaxter »
Great article. Thanks for pointing it out.
