When would 8GB be necessary...
- Legit User
A year or two ago I asked (in a different forum) when 4GB would be necessary... now its just standard! (For gaming that is...).
So I would like to know when would 8GB be worth having, as in when would 8GB of Ram be used at one time...
The easy solution is obviously multi-tasking, but I would like to know more spefically what types of programs would have to be running at the same time....
- martini161
- Mr Awesome
Re: When would 8GB be necessary...
8gb ram is only really necesary when you are doing alot of video editing, or editing HUGE pics
- kenc51
It's not even that necessary for video editting. With Video editting you need 2GB and a fast HDD.
Photoshop editting very large res pics, CAD/CAM and some other specialised programs will use 4GB+
Also database servers, as (most) databases are run from memory, but it would want to be a large daabase with a lot of users accessing different parts of the database to require this.
You can thank vista that you need 4GB. On XP 2GB is plenty.
Having said that, I wouldn't mind 4GB sometime soon.
Dan
Dan
5.5gb is needed when watching a HD movie on VLC media player. Editing pics on photoshop compressing pics to a 7zip file. and browsing the web.
You look like a busy personhercules71185 wrote:5.5gb is needed when watching a HD movie on VLC media player. Editing pics on photoshop compressing pics to a 7zip file. and browsing the web.
2GB for XP, 4GB for Vista, so I'd say 8GB for Windows 7
- martini161
- Mr Awesome
16gb for windows 8? (which will probably be released in 2012 or if things keep on going this way )
haha just a bad case of ADD I think.Zertz wrote:You look like a busy personhercules71185 wrote:5.5gb is needed when watching a HD movie on VLC media player. Editing pics on photoshop compressing pics to a 7zip file. and browsing the web.
Wouldn't 8gb and Vista 64 help with caching more of said game in memory?
AMD 960T OC'ed to 4gz
ASRock 970 EXTREME4 AM3+ AMD 970
2 X G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000)(16gb)
EVGA SuperClocked 02G-P4-2682-KR GeForce GTX 680 2GB 256-bit GDDR5 PCI Express 3.0 x16
To be honest, I think most games are completely cached at 4GB anyway.
With trying to run 8GB regular mobo's (i.e. not server ones), you start to run into problems with the chipset struggling to keep up with the amount of RAM.
Although chipsets are listed as 'supporting 8GB of RAM' in practice getting it to work will be a pain.
Dan
Dan
- aircommando13
- Legit Fanatic
In 10 years we'll be laughing at 2gb and 4gb setups , probably 64-128gb of DDR5 at this rate
Intel E8500 @ 4.0GHz
4GB(2 x 2GB) DDR2 800MHz
EVGA 750i SLI FTW
Seagate 7200.11 500GB HD
EVGA GTX 260 55nm
Antec 630 watt PSU
Samsung 22x DVD/+/-RW Burner
Antec p182 Case
EVGA 750i SLI FTW
EVGA GTX 260 55nm
Antec 630 watt PSU
Antec p182 Case
- JohntechUPi
- Legit Aficionado
There are some articles in relation to this like this one from: http://www.tweaktown.com/news/9570 showing the performance gane in the application with more memory installed. And I am sure there are more. But most people do not do or run applications and the right O.S. to properly utilize more than two or 4 gig of memory. So it really comes back to what and how you are planning to use your system.
IE what O.S. will you use and what applications will you be using? Will said applications address more then 2 Gig of memory if so how mcuh can they use?
One-liner about business
Producing a system from a specification is like walking on water; it's easier if it's frozen.
