different models
xevious
Legit Enthusiast
Legit Enthusiast
different models
Post by xevious »
i currently have 2x 1 gb ocz platinum rev2 ddr2 6400 (800mhz)
is it possible to run that with another ocz ram that is not the same model?
OCZ DDR2 2GB (2x1GB) PC2-6400 800MHz Dual Channel Kit - OCZ2P8002GK Platinum XTC Edition
P5B Deluxe/wifi
E6400 @2.72
Kingwin 12025 cooler (Xigmatek S1283)
evga 8600gt (790, 930, 1738)
ocz platinum rev 2. 2gb (850)
DMB2000uk
Re: different models
Post by DMB2000uk »
Yes it is possible.
If both memory sets are not the same specifications, i.e. different voltage or different timings, then you will have to run both sets/sticks at the highest timings/voltage of the two to ensure they all work properly.
You can however choose to overclock the slowest RAM to match the fastest RAM, but you will need to do stability tests to make sure it will work ok at the faster timings after you do that.
Dan
Image (<- Clickable)
