Memory Voltage Help
- Legit Little One
Memory Voltage Help
I've been running OCZ 2gb (2 x 1gb) in my computer for over a year now with XP 32 OS. I recently bought this http://www.newegg.com/Product/Product.a ... 6820227479. I added it to my computer for a total of 6gb of RAM. But now it won't work and I keep upping the voltage. It started out not booting, then the graphics were messed up and the keyboard and mouse wouldn't work. Then the keyboard and mouse wouldn't work again. And now its up to 2.50 and still not stable. I have Win 7 64 bit to install, but I wanted to make sure the RAM setup was fine before I installed it. I read that only the 64bit XP would recognize the 6gb of RAM. So I'm thinking I need to install the Win 7 64bit, and then deal with adding the RAM. Any thoughts?
- Legit Little One
Re: Memory Voltage Help
From what I remember it is the same RAM, OCZ etc.
New ram has to match all these specifications:
Brand OCZ
Series Gold
Model OCZ3G1333LV4GK
Type 240-Pin DDR3 SDRAM
Tech Spec
Capacity 4GB (2 x 2GB)
Speed DDR3 1333 (PC3 10666)
Cas Latency 9
Timing 9-9-9-20
Voltage 1.65V
Buffered/Registered Unbuffered
Multi-channel Kit Dual Channel Kit
Heat Spreader Yes
Features Gold Layered Z3 XTC Heatspreader
Compatible with Dual Channel Intel Core i5 & i7 CPU for P55 chipset motherboard
Manufacturer Warranty
Brand OCZ
Series Gold
Tech Spec
Cas Latency 9
Timing 9-9-9-20
Voltage 1.65V
Heat Spreader Yes
