512DDR PC3200 only run at 266 in my Chaintech 9PJL3 800FSB?
copperpony_48
Legit User
Legit User
Post by copperpony_48 »
Why does my 512DDR PC3200 400 Memory only run at 266 when is should be running at 400?
http://www.chaintechusa.com/tw/eng/prod ... &PISNo=181
The memory is a hynix memory 512MB 400mhz
kenc51
Post by kenc51 »
What CPU are you running???
copperpony_48
Legit User
Legit User
I tried a 2.4Ghz Celery straight 400 chip. could be D spec, wanting to still try my mobile P4 1.6 CPU in this Mobo , do you maybe think its cos its only a 400 chip? that it runs @ 266?
kenc51
Post by kenc51 »
yep....
I think you can set 333 in the bios too....i can't remember, I ran the same kinda setup for a folding rig last year, but I set the ram to 266 and overclocked to 400 - 2.4GHz to 3.6GHz
copperpony_48
Legit User
Legit User
This sounds interesting, um.... and the cooling? Standard HSF?
kenc51
Post by kenc51 »
Used a zalman CNPS7700-Cu HSF, Asus P4P800dlx mobo (865 chipset like yours).....
The cpu only needed .1v extra to clock to 3.6 and could do 3.4 with default voltage (1.375v) 8)
I ended up killing it :(
copperpony_48
Legit User
Legit User
Oh, noooo I know all too well how that feels :( killed a 1,8mhz P4 514k Mobo chip in a similar fashion playing with voltage mods, Oh well.... next project coming up is 1.7mhz Celeron 128k 400 that comes without the pesky speedstep technology.
