memory timings
- InspectahACE
memory timings
i got a 2gb kit of patriot ddr2-800 ram timed at 4-4-4-12...but cpu-z sees it at 5-5-5-15...i manually set it to the 4-4-4-12..but the system gets unstable so i left it at auto..im at a loss here...i was thinkin its the mobo since it was the only piece in my system that wasnt more than $150...but im not gonna keep that assumption since cost isnt always the factor of somethin wrong lol..any ideas?
- InspectahACE
its set at 1.85v...i left the pc on runnin on 4-4-4-12 manually..havent seen the rig go down yet..but i havent been home to see it lol...so far so good...if it goes..ill try that 2.0.v ....i was startin to wonder if it was undervolted..thanks:)..will keep ya'll posted on it..thanks again
- InspectahACE
wtf lol..i set the voltage to 2.0 and manually set the ram at 4-4-4-12 for $hits and gigglez..and now i see in cpu-z that it ssayin the timings are at 3-4-4-20 with 2:3 divider it looks like...arghhh
- InspectahACE
they at the voltages Patriot says they should be at..(2.2v) set it at 4-4-4-12 again and its still showin 3-5-5-20.....couldnt find a bios update tho :/
- InspectahACE
yes i manualyl set them after i set the voltage..but i am a lil confused on what ya mean by settin them to SPD settings tho
- InspectahACE
thats what i figured after i signed off to look...sorry lol.i did what ya mentioned kenc..but its still not lookin like its doin it...i took these screen grabs to show what cpu-z says to show if im doin anythin wrong from it if possible
- InspectahACE
well after more digging..i found that the SPD timings are intially 5-5-5-15..but says they were tested at 4-4-4-12 at 2.2v and after adjusting the timings manually im still comin up at 3-4-4-20...which looks better but i dunno lol damn it...im sure its not a real big issue..but it bothers me that i paid $250 for this kit to run at 4-4-4-12 and im not gettin it..
- kenc51
3-4-4-20 is better than 4-4-4-12!!!!InspectahACE wrote:well after more digging..i found that the SPD timings are intially 5-5-5-15..but says they were tested at 4-4-4-12 at 2.2v and after adjusting the timings manually im still comin up at 3-4-4-20...which looks better but i dunno lol damn it...im sure its not a real big issue..but it bothers me that i paid $250 for this kit to run at 4-4-4-12 and im not gettin it..
Check your bios for TRAS and change that to 12 your currently at 20
TRAS doesn't give much performance, but CAS does!
Are you planning to OC the ram past 400? If so, change the CAS to 4 (currently on 3)
- InspectahACE
well then lol..the TRAS has been set at 12 in the bios the whole time so why its 20 ill never know...im not plannin on OC'ing anytime soon..just was weirdin out why the sticker on the ram an all say those timings but wasnt gettin them...anyhow...kenc..ur the man..you've helped me out alot..thanks:)
- kenc51
NP.InspectahACE wrote:well then lol..the TRAS has been set at 12 in the bios the whole time so why its 20 ill never know...im not plannin on OC'ing anytime soon..just was weirdin out why the sticker on the ram an all say those timings but wasnt gettin them...anyhow...kenc..ur the man..you've helped me out alot..thanks:)
But you should try lowering the TRAS anyway! If it doesn't set to 12, try around ~14. But even then I doubt you'll see any improvements.......mayby ~8mb/sec in Sandra benchmarks
- InspectahACE
ill give it a shot..maybe not much improvment but long as its stable lol..it will make it look better anyway...thanks again
- InspectahACE
i do think its the mobo though(either that or somethin lol)....i was just messin around...i put the TRAS at 14 in the bios and it went up to 22 in cpu-z...so i figured id try somethin and go way below in the bios..the bios let me go down to 4 on the TRAS...and now cpu-z says i got 3-4-4-12 at 800 mhz ddr2....now...so far its stable LOL...whether how much better who knows..but if it doesnt hurt the ram at stock speeds then im all for it...im just glad it works at the timings u helped me with ken
- kenc51
Your welcome......I'm glad you got it sorted!
But that's just cazy
But as you said, if it's stable......who cares?
You should run "Orthos" blend test for a while to be sure it's stable
http://www.techpowerup.com/downloads/385
also 2x instances of superpi 32M tests
http://www.xtremesystems.com/pi/
Ken
Ken
- InspectahACE
yea it is crazy..had to do a lil math to see what i would get lol...hate math..but ill run those tests to make sure...never really tested this new rig to see how it is..i know it eats games and movies and whut not alive..but never ran it thru a test
- InspectahACE
hehe no game liked those 3-4-4-12 timings lol..oh well..least i know what it can do
