Recommendations for a HTPC
A place to talk about A/V receivers, Blu-Ray players, LCD or Plasma TV mounting, audio tips or anything else that you think fits.
wollyka
Legit Enthusiast
Legit Enthusiast
Post by wollyka »
Hi
I am looking into building a HTPC for the living room to replace the old dead VHS video recorder but i need recommendations from the experts here since i never built one before (only desktop pcs).
Well, obviously, the case should be compact (not much space available in the room) and if it has a small LCD built in the better (optional).. Also i am searching for quiet components (PSU, CPUs fans, HDDs) since well you know it is in the living room and i don't want it to sound like my main PC (which is very loud with 8+ fans in it)..
The power consumption should be reasonable too since it will be used most of the day..
Main uses: Record live tv shows +DVR+ act like a media storage center (the usual stuff)
Any recommendations?
Thanks
System:
-Intel Core 2Quad Q6600--ECS PN2 SLI2+ 680i-4GB OCZ DDR2 PC2-8500 SLI-ready Edition-XFX Geforce GTX280--X-fi Fat1ality FPS-Thermaltake Toughpower 1200W PSU-LG Flatron L1710B
wollyka
Legit Enthusiast
Legit Enthusiast
Re: Recommendations for a HTPC
Post by wollyka »
For those interested, i found this guide: very good read
Code: Select all
http://www.avsforum.com/avs-vb/showthread.php?p=14239742
System:
mr_noname111
Legit Aficionado
Legit Aficionado
Post by mr_noname111 »
Well if you aim for low power, you will naturally get a quiet PC. An e4850 and a mATX 780G mobo seems to be the best option ATM, you could probably buy a Scythe ninja cooler (I believe the ninja mini could fit in most small cases) and run it passively for absolute silence. 2.5" hard drives are also very good for silence and low power, but since you plan on using it to record TV, you should probably get big capacity 3.5", you will need a couple of terabytes to record HD. I recommend getting a case that fits a standard ATX PSU instead of a proprietary one, and get a quality PSU, maybe even a fanless one.
One more thing, unless you are gaming, the 780G's IGP is plenty. So don't waste money on a dedicated graphics card for running 1080p.
Here is a guide for different categories of HTPCs:
http://www.bit-tech.net/hardware/pcs/20 ... rs-guide/1
EDIT: Ahh, I didn't see that you already found a good guide :P well either way, good luck on your HTPC!
Main Rig: E8400@3600mhz, Asus P5Q, OCZ 4GB, EVGA GTX260 216, Corsair HX520, Antec 300, Samsung 2443BW
HTPC1: E5200@2500mhz, EVGA 780i SLI, OCZ 2GB, Asus 9600GSO, OCZ GameXStream 600W, LG 47LG70 LCD TV
HTPC2: E6500@3300mhz, DFI DK X48 T2RS, Kingston 2GB, Palit 9800GT Green, BFG 550W, Acer H5360 720p 120hz Projector
wollyka
Legit Enthusiast
Legit Enthusiast
Post by wollyka »
Thx for the guide and advice. and yes i am leaning towards a 780G right now (i don't plan on gaming or heavy 3D so the IGP will do just fine)
and thx for wishing me luck :)
System:
mr_noname111 wrote:One more thing, unless you are gaming, the 780G's IGP is plenty. So don't waste money on a dedicated graphics card for running 1080p.
I have a 780G on my HTPC and it has a very slight stutter to it... If you have a 50+ inch 1080P I suggest adding in a card like a passive Radeon HD 4670.
martini161
Mr Awesome
Mr Awesome
Post by martini161 »
sure the stutter isnt due to the fact thats its doing 60hz as opposed to 24?
wollyka
Legit Enthusiast
Legit Enthusiast
Post by wollyka »
Thanks for the advice, i don't have a 50+ inch TV (only 36 inch TV), so i pan first to use the integrated chipset then upgrade to a discrete GPU when i have more money :)
System:
mr_noname111
Legit Aficionado
Legit Aficionado
Well the IGP on the 780G is basically a 2400XT, a respectable GPU for 2D. I've actually even played some games on it like L4D, GTR2 with some success. Personally the stuttering that I've noticed with my setup is the TV's fault, not the computer's.
pwcmed
Post by pwcmed »
What are you doing when it stutters?
