My second mobo had a bad floppy controller. Long story short, the BIOS wouldn't take new settings, replaced the CMOS battery, still no dice. Tried to upgrade, didn't work and then the floppy controller died, meaning I have a half-flashed BIOS that I can't recover from.
I'm sick of MSI's bull**** and I want a new board.
I was looking at the Asus A8N32-SLI Deluxe. Anything bad about this board? What other options should I consider? Throwing everything out and buying a Core2 is NOT an option!
Replacement for K8N Diamond Plus
Play
Work
Work
- JohntechUPi
- Legit Aficionado
You cant go wrong with ASUS in my opinion, they sell more then 45 Million MB's a month if you include all the OEM MB's.
But realisticly any of them can have a mistake, and do, but I have had good luck with ASUS for the most part but the A8V I have is giving me fits with 4 modules is the only thing I have seen recently. But a lot of MB's have problems with 4 modules.
One-liner about business
Producing a system from a specification is like walking on water; it's easier if it's frozen.
A8N32-SLI Deluxe in the mail, expected arrival on the 14th. Screw MSI, Asus FTW!
Play
Work
Work
