Hi,
My name is Ajeeth. I recently purchased M3A32-MVP-DELUXE motherboard and a XFX Geforce 9600 GT Graphic card. My computer configuration is this:
Motherboard - M3A32-MVP-DELUXE
Processor - AMD Athlon 64 X2
Power supply - Zebronics 450 W
Graphic card -Geforce 9600 GT
RAM - 2 X 1 GB Corsair (Matched Pair)
All the components mentioned above are brand new.
I have installed all the drivers from the Asus and XFX CDs on XP environment. .
I am getting this issue a lot of times - Blue screen and random reboot.
I checked in the eventvwr and found these system errors:
Error code 1000008e, parameter1 c0000005, parameter2 bf8021e1, parameter3 b346fc74, parameter4 00000000.
Error code 10000050, parameter1 bf6fd406, parameter2 00000008, parameter3 bf6fd406, parameter4 00000000.
Error code 1000008e, parameter1 c0000005, parameter2 806330ec, parameter3 b31ff8e8, parameter4 00000000.
Error code 1000008e, parameter1 c0000005, parameter2 00000083, parameter3 b2b8c6bc, parameter4 00000000.
Error code 10000050, parameter1 80020000, parameter2 00000008, parameter3 80020000, parameter4 00000000.
Error code 100000d1, parameter1 006f0078, parameter2 00000002, parameter3 00000001, parameter4 89724732.
Error code 1000008e, parameter1 c0000005, parameter2 805bad24, parameter3 b3177c94, parameter4 00000000.
Error code 1000000a, parameter1 9ae7a900, parameter2 00000002, parameter3 00000001, parameter4 8052181f.
Error code 1000000a, parameter1 8a522b00, parameter2 00000002, parameter3 00000001, parameter4 80521803.
Can you please let me know what could be the cause for the problem? This is happening on a regular basis and am not able to work on it.
Any help is appreciated.
Thanks,
Ajeeth
Random blue screen and restart- M3A32-MVP Deluxe
- Legit Little One
Re: Random blue screen and restart- M3A32-MVP Deluxe
Well from the general trend of the errors they are supposed to be caused by hardware compatibility issues. Most likely a driver problem.
You should update the drivers for the motherboard and graphics card to the latest from the respective websites (nvidia and asus).
You did reformat and run a fresh install of windows with the new motherboard right? If you didn't then that is the cause of the problems.
Dan
Dan
- Legit Little One
Hi Dan,
Thanks a lot for your reply. Yes, I formatted the system and installed XP once I got the motherboard. As advised by you, I will check and apply more driver updates for both the Asus and Nvidia components and let you know.
Cheers!
Cheers!
I would also suggest checking if there are any BIOS updates for your motherboard. I had a similar problem recently; despite obtaining the latest drivers for all the components, the blue screen struck like clockwork every time a particular program was opened. I updated the motherboard's BIOS and it hasn't blue-screened once in about 3 weeks.
If that doesn't work you may want to check up on your memory. If you have two sticks, take one of them out and see if the blue screen still happens. Then test the other one by itself as well.
Good Luck!
Good Luck!
Case=Antec Twelve Hundred
Mobo=EVGA 790i Ultra SLI
CPU=Intel Q9450 OC @ 3.7 Ghz
GPU=GTX 280 X 2 SLI
RAM=Corsair DDR3 1600 9-9-9-24
Sound=Creative X-fi Xtreme Gamer
PSU=SilverStone DA1000 1000W
3DMark Vantage=Overall-21,591
CPU-43,435
GPU-18,491
GPU=GTX 280 X 2 SLI
CPU-43,435
GPU-18,491
Thats exactly what I was to suggest next
A better way of testing memory is via memtest86+. Download and burn it to a CD then boot from the CD and let it run.
Dan
Dan
Do you happen to know of any descriptions and or instructions that explain how to read and understand Memtest? I've tried it on a few setups, but I'm not sure what to look for to see if the memory failed or passed. There were quite a few 'failed' and 'passed' messages that seemed to reset and change every few seconds.
I don't mean to hijack this thread, but since the issue has come up, perhaps a little enlightenment on this tricky program would be good for people like myself.
GPU=GTX 280 X 2 SLI
CPU-43,435
GPU-18,491
GPU=GTX 280 X 2 SLI
CPU-43,435
GPU-18,491
- stev
There are reports flying around the web dealing with XP SP3 causing the blue screen and continually looping reboots. This is only happening with AMD processors. The INQ has a report on this.
XP SP3 crashes AMD machines
Here we go loop de loo
http://www.theinquirer.net/gb/inquirer/ ... d-machines
ok first off as for AMD cpu based machines crashing with xp sp3 that is to with an oem bios issue nothing to do with the cpu and it's mostly on HP machines which they and Microshaft are comming up with a patch to fix it
now back on topic
its your PSU it's under powered for your setup a 450W is the bare min needed to boot your system let alone have a enough power to do any work with it upgrade your psu to atleast a 550W model of a descent brand name
now back on topic
Asus Crosshair V Formula
AMD FX 8320 @ 3700MHz NB/HT @ 2600MHZ
2x 4GB Corsair Vengeance LP 1600 C9
1x Sapphire Radeon HD 7850 9550MHz core 1250MHz mem
1x Pioneer DVD-RW DVR212S SATA
2x Samsung HD502IJ 16MB cache 7200rpm raid0
1x Samsung HD502IJ 16MB cache 7200rpm storage
1x WD2500AAJS 8MB cache 7200rpm storage
Thermolab Baram 1 x 120mm CM R4 90cfm 2000rpm 1x SilverStone 120mm AP 1500rpm 37.5cfm
SilverStone ST75F-P 750W PSU Full Modular
SilverStone RaVeN RV02B-W
