m2n32-sli dlx nforce 590
Discussion about AMD CPU Motherboards
darkman
Legit Little One
Legit Little One
Post by darkman »
would you by this motherboard if you found it forsale retail package for $69.oo
SAMSAMHA
Re: m2n32-sli dlx nforce 590
Post by SAMSAMHA »
if you simply needa cheap system, it woudl be a good choice.
camaroguy1998
Post by camaroguy1998 »
darkman wrote:would you by this motherboard if you found it forsale retail package for $69.oo
I have the CrossHair which is basically the same board with a few more Whistles and Bells and I love it!
Its been very reliable!
It is behind on the chipset curve but for $69 thats hard to beat!
Corsair 4000D Airflow
JohntechUPi
Legit Aficionado
Legit Aficionado
Post by JohntechUPi »
ASUS M2N32-SLI Deluxe and the Wireless edition are great MB's I have a few of them running and with the latest BIOS will run the phenoum CPU's
Note though if you flash to the latest BIOS they will not post with the older CPU's at least mine dont.
By the way that MB sells for like 240.00 USD on Newegg and Tiger Direct, where did you find such a good price if I may ask?
One-liner about business
Producing a system from a specification is like walking on water; it's easier if it's frozen.
