Biostar TA760G M2+
Discussion about AMD CPU Motherboards
jedihobbit
Legit Fanatic
Legit Fanatic
Biostar TA760G M2+
Post by jedihobbit »
I've picked up the above board to replace a 780G that I fried while "leak testing" a WC build. It appears to be pretty much the same with exception of onboard GPU. Initially it was going to use an 8750BE but was able to rustle up a 720BE instead. Originally thought there would be an issue with the bios but it seems the January bio was fine.
IS there anyone here that is familiar with this mobo?? Trying to do some oc'ing and may need to ask for some "fine tuning" help as of right now I'm just playing with the voltage, multi, and FSB as well as memory settings.
Now on to other questions.........
Is there anyone who could tell me where these temp values are coming from other than the obvious core, gpu, and hdd? Ya know like NB, etc....... :rolleyes:
DreamCatcher v4.0 DOA >> SG01 Evo, TA790GXE, PII X4 945 (AQ H2O Cooled), BFG GTX280 H2OC, Seagate 7200.10 ST380815AS 80GB, 2 x WD5000KSs, TWIN2X4096-8500C5DF, MODU82+ EMD525AWT, XP Home SP2
Kermit v4.0 VIRUSed >> Ultra MX6, 785GM-E65, PII X4 955 @ 3.70GHZ(air), XFX GTX285, Raptor X, F3-12800CL7D-2GBPI, OCZ700MXSP ModXStream Pro, XP Home SP2
Oz1a v2.0 >> XFX MDA72P7509 750a, PI X2 8870BE @ 3.00GHZ(air), 2 x XFX GTS250, WD 250GB, F2-8500CL5D-2GBPK, Tt TR2 600W, XP Pro SP3
jedihobbit
Legit Fanatic
Legit Fanatic
Re: Biostar TA760G M2+
Anyone? :?
spitter
Post by spitter »
acpi/thrm= motherboard cpu diode
tmpin1 = north bridge diode I believe.
Might want to download Everest and compare values.
jedihobbit
Legit Fanatic
Legit Fanatic
spitter wrote: Might want to download Everest and compare values.
8) Keep threatening to do that, may just have to break bad and do it! :)
