need help updating RAM in D975XBX2
slickmarty
Legit Aficionado
Legit Aficionado
Post by slickmarty »
i have the D975XBX2 MB with 4 1GB sticks of Corsair RAM. when i went from 2 1GB sticks to 4 i thought that i bought the exact same thing but didn't and had a heck of a time until i figured out that i the new two weren't EXACTLY the same. i want to get 2 2GB sticks for channels 1&3 and hopefully keep cahnnels 2&4 with the 1GB sticks until i can get two more 2GB sticks. will this work??? since this in now a little older of a MB there aren't many tested RAM modules on the Intel MB support site so how do i know what will work? has anyone here put 2 GB sticks in their D975XBX2? what kind and what EXACT part number if you would please. I saw this on N**E** and it SEEMS like a match but i am not sure.
CORSAIR XMS2 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model TWIN2X4096-6400C5C - Retail .
http://www.newegg.com/Product/NewProduc ... -_-Product
any help would be much appreciated.
thanks.
slickmarty
Legit Aficionado
Legit Aficionado
Re: need help updating RAM in D975XBX2
i've been searching N**E** for RAM and have found lots of DDR2 240pin DDR2 800 PC2800 RAM from different companies and ever the Corsair has 5 or 6 sticks that meet this criteria.. how is one to know which of these will work???
thanks
smack323
Post by smack323 »
well this memory is listed on Intel site as "tested memory"
http://www.amazon.com/dp/B000FGD3WQ/?ta ... pai87cr2_b
these are the specs:
The board has four DIMM sockets and supports the following memory features:
1.8 V and 1.9 V DDR2 SDRAM DIMMs
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
8 GB maximum total system memory
Minimum total system memory: 128 MB
ECC DIMMs and Non-ECC DIMMs
Serial Presence Detect
DDR2 800, DDR2 667, and DDR2 533 MHz SDRAM DIMMs
I would say that any kits from Newegg that fits in line with these should work- I have used Patriot, G.skill, Cosair memory kits all with no problems
bubba
Staff Writer
Staff Writer
Post by bubba »
-Thomas Jefferson
Sparky
Post by Sparky »
I've used this Corsair XMS PC6400 with no issues:
http://www.newegg.com/Product/NewProduc ... 6820145590
I've also used this Kingston HyperX PC6400 with no problems:
http://www.newegg.com/Product/NewProduc ... 6820104073
Right now I'm using this G.Skill PC8500 (easier to OC than PC6400) with no complaints:
http://www.newegg.com/Product/NewProduc ... 6820231166
I've never been able to get my XBX2 to work with 4 - 1GB sticks, even when they were matched sticks. Sometimes it wouldn't boot and if it did boot it was very unstable.
slickmarty
Legit Aficionado
Legit Aficionado
thanks. i'll look into these.
northernpal
Legit Little One
Legit Little One
Post by northernpal »
I am using these without any problems
G.SKILL F2-8500CL5D-4GBPK PC2-8500 4GB 2X2GB DDR2-1066 CL5-5-5-15 240PIN Dual Channel Memory Kit
http://www.ncix.com/products/index.php? ... re=G.Skill
Once the system is stable (Overclocking a Q6600 and will be trying my luck with a QX6850 as well) I will try and use 4 x 2GB for 8GB total (but for now running fine with a 4GB kit)
I have two other BadAxe2 machines running with four 1GB sticks fine (for years) but I do know that these boards are not as stable when all 4 slots are filled (and I have even heard of a few folks having memory get fried when moving up to 4 slots ..)
It has been awhile since I configured the 4x1GB systems but if someone wants more info I will look into the BIOS settings etc.
System: D975XBX2 MB Revison:505 BIOS:2838, Q6600, 2 x 2GB G.Skill PC2-8500 DDR2-1066 MHz, BFG 8800GT OC2 512 PCIe; plus all the usual other stuff....
slickmarty
Legit Aficionado
Legit Aficionado
i know that when i went from the 2 1gb sticks of ram to 4 of them i had a lot of stability problems but the second sticks of 1gb RAM that installed were not EXACTLY a match for the first 2. when i got the exact same match the system has worked fine and stable for years now. What is in there now and working fine is: Corsair MEM 1Gx2Corsair Twin2x2048-6400 R. When i added the MEM 1gx2/Cor 240P Twin2x2048-6400C4 is when things went crazy, atomatic re-booting, crashes and other instability. as soon as i removed the c4 and installed two more sticks of the R everything was perfecto...
