Does SATA HDD works on SATAII connector motherboard?
- Legit Little One
I'm deciding to buy new motherboard that would support intel i7, but all new motherboards are SATAII so does SATAI HDD works on SATAII connector motherboard because I'd like to keep all my files including windows files. The old disc product nr. is WD5000AAKS.
- Sparky
Re: Does SATA HDD works on SATAII connector motherboard?
SATA II will work fine, it's backwards compatible.
- Legit Little One
Thank you for your answer
all internal SATA drives/motherboards so far are backward and forward compatible
-Austin
Screamin' BCLK:
Screamin' BCLK:
