Hello Fellow Legit'rs!
I was curious if any of you know about the AW9D motherboard yet. Will it perform just as good as its bigger brother? Does it use all the same chipsets, ect? Does it use the same bios?
I know the MAX has the extra heatpipe, LAN, and more SATA slots... I think the rest is the same though...
Just curious if anyone has seen any reviews around for this board, if it will hold up just as well as its bigger brother. I am seriously considering buying one if I hear good reviews about the MAX, hoping the vanilla AW9D will perform similar (of course not as well as the max --- maybe a bit lower, but not have anymore problems the MAX has, ect).
You dont have any tests of the AW9D do ya LR?
Thanks much guys --- hope to hear back,
AJ
