D975XBX2 Blue Sockets
Since I have gotten no responses to my first dilema, let me state it a different way. Is there any way to make the blue SATA sockets perform the same way as the black sockets - able to accommodate a hard drive or optical drive type?
Ted
- Legit Aficionado
Ted-
I have used both a single, normal SATA drive as well as a 2-drive RAID 1 setup on the blue sockets (Marvell) with no problems. I have not tried an optical drive on any of the SATA ports. I'm currently not using the Marvell SATA, and I've got 4 drives in a RAID 5 setup on the Intel SATA.
What problem are you having trying to use the blue sockets? Are you trying to use both, or just the blue sockets?
Sean
Sean
Hi Sean - thanks for the reply - I have all of the black sockets tied up with hard drives and the IDE path currently contains 2 optical drives. I am attempting to add 2 additional optical SATA drives and need to use the blue sockets. I am wondering if I should move a couple of the hard drives over to the blue sockets, set up a raid array on those, and try the opticals in the now vacant black sata sockets. From what I have read, sata optical drives can be troublesome to set up.seanriddle wrote:Ted-
Sean
Ted
- Apoptosis
- Site Admin
Same deal here... I haven't tried a SATA optical drive as I don't have one.seanriddle wrote:Ted-
Sean
Well, pretty much answered my own question(s) - I moved 2 hard drives to the blue sockets which are still disabled. Moved the 2 SATA opticals to the black sockets where they were immediately recognized and configured by XP. Now I supposed I'll make a RAID array at the blue sockets and use them for video storage - a RAID 0, I think.
Ted
- Legit Aficionado
