My case is a kind of Lian Li case :-
2x Silent Fans at the front to bring the air in
2x Silent Fans At the back to blow air out
1x Silent Fans on top to draw the air out
1x Zalman CNPS7000A-Cu Ultra-Quiet CPU Cooler
My cpu temp is about 47-49 normal use (no games) and I get lots of negative feedback about my Temps !
It runs at about 60oC playing games
My motherboard Temp is 35oC
47 is to high, cofirmit in the bios, Then get some decent thermal paste and re seat you're heatsink
your temp is too high my cpu runs at 32/33 at normal use thats with 2 of my fans switched off
60 deg is to high For the CPU (mines 45 at worst with far cry) what does it idle (or intenet use) at temp wise, Im using just the standard intel cooler
Any Ideas or reply will be much appreciated
Ive got :-
P4 3.20(e)ghz
Asus P4C800-E Deluxe
1GB Corsair DDR XMS3200C2 Pro TwinX
2x74gb WD Sata Raptors
Hansol 17" LCD
BTC DVDRW IDE1008
GforceFX 5900 256mb DDR
SecuGen Biometric Mouse
Zalman CNPS7000A-Cu CPU Cooler ( Fan running at 2360 )
1.1mbps ADSL
550w PSU, XP pro
