i5-3450 3.1GHz @ 3.9GHz
BASGTA
Legit Little One
Legit Little One
Postby BASGTA » Tue Jul 31, 2012 3:51 pm
I bought an i5 3450 a few weeks ago. I heard that the max frequency was locked at 3.5GHz by Intel. However my motherboard (Z77 Pro3) allows me to adjust the clock right up to 39, allowing for 3.9GHz
With Intel Speedstep on, all software that monitors clock speed will show speed constantly changing. With it off, only a few programs show it changing, while others stick to default speed (3100MHz) Again, with Intel Speedstep both on and off the clock bounces from 1600MHz up to 3700MHz - 3800MHz, every once in a while hitting 3900MHz.
With Intel Turbo off I can't adjust any of the settings and it's locked at 3100MHz.
I'm wondering if there's a way to lock the multipler at 39.
DragonFury
Re: i5-3450 3.1GHz @ 3.9GHz
Postby DragonFury » Tue Jul 31, 2012 5:49 pm
thats a non k series CPU, the CPU will adjust automatically according to what you are doing so it will bounce from one to the next, when you have speed step turned on. According to intel that CPU's max Quad CPU turbo multiplier is 35 (HERE) i am guessing the 3.9GHz you are seeing is when the CPU is running 1 core not on all four. so to get 3.9GHz out of it will require you to overclock the BCLK of the board. and it is seriously doubt full you will be able to hit a 112 BCLK on the Z77 based motherboards.
To overclock that CPU it would be a good idea to lock the turbo multiplier to its highest setting, then up the BCLK. Or get a K series CPU.
Mini ME
Is in a state of flux....
Barb
Legit Little One
Legit Little One
Postby Barb » Wed Apr 03, 2013 12:17 am
You cannot expect to tweak the multipliers or the bclk on a B75 chipset. The i5 3450 has a multiplier limit of 39 for a max OC of 3.9ghz. You can only access the multiplier or bclk if you have a z75 or z75 chip set.
Did you try downloading from Intel the Intel(R) Turbo Boost Technology Monitor? I would trust it.
Windows or Linux I don't care, I'd anyways try tweaking it to the limits ! ;)
lordvic
Postby lordvic » Sat Apr 06, 2013 1:36 am
Barb wrote:You cannot expect to tweak the multipliers or the bclk on a B75 chipset. The i5 3450 has a multiplier limit of 39 for a max OC of 3.9ghz. You can only access the multiplier or bclk if you have a z75 or z75 chip set.
The OP states he is running a Z77 chipset-based motherboard.
According to Intel, DragonFury seems to be correct. 3.5GHz is the official maximum frequency "Turbo Boost" can do. Only thing is, I'm stumped on how your chip is "turboing" to 3.9GHz. The latest revision of the "Desktop 3rd Generation Intel® Core™ Processor Family Specification Update" (Dated March 2013) shows the i5-3450 does the following:
4 Core - 3.2GHz
3 Core - 3.3GHz
2 Core - 3.5GHz
1 Core - 3.6GHz
http://www.intel.com/content/www/us/en/ ... pdate.html
(Page 15 of 48)
I'm not sure if the 3.9GHz boost is from the motherboard.
Spamburger
Legit Enthusiast
Legit Enthusiast
Postby Spamburger » Sun Apr 07, 2013 1:52 pm
4 Core - 3.2GHz
3 Core - 3.3GHz
2 Core - 3.5GHz
1 Core - 3.6GHz
(Page 15 of 48)
The method for overclocking these "locked" processors is the same as an i5/i7-K. Non-K type i5s and i7s can be overclocked up to 400 mhz over the stock and turbo frequencies by changing the processor's multiplier.
redwanhasan
Legit User
Legit User
Postby redwanhasan » Sun Sep 22, 2013 12:40 am
you can change the multiplier to achieve higher clock speed.
I have done it on my non k CPU. http://redwanhasan.blogspot.com/2013/06 ... ge-in.html
and you can also adjust turbo to higher speed.
3.5GHz what intel has specified is only single core running scenario.
you can modify that settings too.
you can change turbo ratio to change this.
Core i7 2600
Cooler Master Hyper 412S
Gigabyte GA Z68A D3H B3
16GB Dual Channel 1333MHz
MSI GTX660OC 2GB SLI
Corsair CX750
ASUS MS228
Hitachi 1TB 3Gb/s, WD 2TB 6Gb/s
http://redwanhasan.blogspot.com/2011/01/me-my-blog.html
Return to “Intel Processor Forum”
Who is online
Users browsing this forum: Google [Bot] and 4 guests
