Howto Guide: Overclocking C2D/C2Q Processors v1.6.1
martini161
Mr Awesome
Mr Awesome
Re: Howto Guide: Overclocking C2D/C2Q Processors (v1.4)
Postby martini161 » Fri Dec 07, 2007 12:30 pm
for the next update, i would suggest maybe attaching a printer friendly text only version of the guide? it would save lots of ink
DMB2000uk
Postby DMB2000uk » Fri Dec 07, 2007 12:49 pm
martini161 wrote:for the next update, i would suggest maybe attaching a printer friendly text only version of the guide? it would save lots of ink
The forums can do that for you, on the first page (well any post you want to print), go to the top far right of the greenness (just under the orange nav buttons) and click the printer icon. :mrgreen:
Dan
Image (<- Clickable)
martini161
Mr Awesome
Mr Awesome
Postby martini161 » Sat Dec 08, 2007 12:12 pm
yea, but this doesnt work. it only prints out one page of the first post. dont know if its the PHPBB3, fire fox, or my printer
DMB2000uk
Postby DMB2000uk » Sat Dec 08, 2007 5:45 pm
heh, it breaks in firefox for me too, it displays correctly when the print icon has been clicked, but the print preview shows the first post as running off of the first page, then the second page is the next post.
It works ok in IE (and IE tab in firefox) though.
I wonder if it is the browser or phpbb3's fault.
Dan
oops
Legit Little One
Legit Little One
Postby oops » Sat Jan 05, 2008 3:56 pm
great guide definitely learned a ton, just need some help on my particular setup with a qx6850 evga 680i board, cant seem to up the fsb at all without quick crashes in windows.. i posted a thread in this forum if anyone can help. thanks
FZ1
Postby FZ1 » Sat Jan 05, 2008 4:51 pm
martini161 wrote:yea, but this doesnt work. it only prints out one page of the first post. dont know if its the PHPBB3, fire fox, or my printer
Copy and paste into Word or Open Office word proc (I forget the name).
Joe
Cannyone
Legit Fanatic
Legit Fanatic
Postby Cannyone » Sun Feb 03, 2008 9:13 pm
Very Impressive Guide! Almost makes me want to go back to my P5B-Plus... nah! That doesn't make sense! I'm not trying to play Crysis, and all the other current crop of games work fine. :)
Intel Core i7 4820K @ 4 GHz | Asus Rampage IV Formula | 16GB Patriot DDR3-1866 | Asus Poseidon GTX 780 water cooled... (other stuff too <- 500 char limit!)
hnzw_rui
Postby hnzw_rui » Wed Mar 05, 2008 8:44 am
Awesome. First-time overclocking and I got my E2160 to 2.40GHz following this guide with only one minor hiccup. :supz:
I could probably go higher but 60C at load is the max I'm comfortable with (using stock HSF).
unRAID Server
graysky
Legit Aficionado
Legit Aficionado
Re: Howto Guide: Overclocking C2D/C2Q Processors (v1.5.1)
Postby graysky » Sat Mar 08, 2008 6:32 pm
Cool man, glad you found it useful.
http://encoding.n3.net <--- for all your DVD and audio CD backup needs!
graysky
Legit Aficionado
Legit Aficionado
Re: Howto Guide: Overclocking C2D/C2Q Processors (v1.5.2)
Postby graysky » Sun Mar 23, 2008 5:49 am
Version is now 1.5.2 (updates in first post)
graysky
Legit Aficionado
Legit Aficionado
Re: Howto Guide: Overclocking C2D/C2Q Processors (v1.6)
Postby graysky » Sun May 04, 2008 5:03 pm
Guide is now version 1.6
• Added a detailed section to help you find the minimum stable CPU and MB vcore settings. Check it out (near the bottom of the guide entitled, “Stress Testing and Minimizing Your Vcores”)!
• Updated the CPU table
• Provided a less than $5 method you can use to shave off some NB load temps (in the thermal management section at the end of the guide).
DMB2000uk
Postby DMB2000uk » Mon May 05, 2008 4:47 am
Thanks for keeping working on this graysky, I still refer people to your guide when they need to know the ins and outs of overclocking ^_^
Dan
graysky
Legit Aficionado
Legit Aficionado
Postby graysky » Mon May 05, 2008 2:08 pm
Thanks man, knowing that people are finding it useful makes all the writing worthwhile.
Bishop25
Legit User
Legit User
Postby Bishop25 » Tue May 06, 2008 8:12 pm
always wanted to learn how to overclock my computer. Thank you for this guide it help out alot now here's hoping I don't kill my computer. :)
graysky
Legit Aficionado
Legit Aficionado
Re: Howto Guide: Overclocking C2D/C2Q Processors v1.6.1
Postby graysky » Sat May 10, 2008 3:54 am
Version 1.6.1 is up. Totally re-wrote the section on memory which now includes a discussion on both DDR2/DDR3 and formulas you can use to calculate max supported FSB of a given module based on it's DDRX-Y and PCX-Y designations. Also re-ordered the first part of the guide.
deleted
Legit Fanatic
Legit Fanatic
Postby deleted » Wed Jul 15, 2009 4:16 pm
I don't have a Core 2 Duo or Core 2 Quad, but I do have a Pentium Dual Core E2220, which was listed in this post as a C2D. Does the same process apply to Pentium D's?
hnzw_rui
Postby hnzw_rui » Sun Jul 19, 2009 9:33 am
Evasion wrote:I don't have a Core 2 Duo or Core 2 Quad, but I do have a Pentium Dual Core E2220, which was listed in this post as a C2D. Does the same process apply to Pentium D's?
Core 2-based Pentium Dual-Cores (E2000, E5000 & E6000 series), yes. Note, I was using a Pentium E2160 (1.80GHz stock). The same should apply to the new (Core 2-based) Celerons.
unRAID Server
Return to “Intel Processor Forum”
Who is online
Users browsing this forum: No registered users and 0 guests
