iBuyPower Gamer Paladin System with an Intel Core i7-870 CPU
Major_A
Re: iBuyPower Gamer Paladin System with an Intel Core i7-870 CPU
Postby Major_A » Thu Oct 08, 2009 12:40 pm
I live in Houston, you could've had it delivered here and I'd have signed for it. Problem with that would be you'd come to pick it up and I'd already have it plugged in and trying to find it's max OC.
x.clay
Legit Aficionado
Legit Aficionado
Postby x.clay » Thu Oct 08, 2009 3:14 pm
I actually live just north of Houston (Woodlands) but close enough.
That would have saved my some time :lol:
CPU: Intel Core i5-2500k
Mobo: Asus Z77 Gene
GPU: GTX 470
RAM: 2X4gb G.Skill 1600
OS SDD: Kingston 120 gb SSD
Game SSD: Kingston 128 gb SSD
Storage: Hitachi 1Tb, Intel 80 gb SSD
PSU: Corsair AX 850w
Case: Silverstone FT-03
gibbersome
Legit Enthusiast
Legit Enthusiast
Postby gibbersome » Thu Oct 08, 2009 3:16 pm
x.clay wrote:I actually live just north of Houston (Woodlands) but close enough.
BTW, now that you have an awesome gaming rig, can I have your old one? :)
gibbersome
Legit Enthusiast
Legit Enthusiast
Double post. *grumble*
x.clay
Legit Aficionado
Legit Aficionado
Postby x.clay » Fri Oct 09, 2009 8:17 am
Intel and IBP put together a pretty sweet system. I haven't had a chance to try any games but I have WiC loading and I'll probably get Hawx, Crysis, and few other loaded up later. I'll get a some more pictures up once I have a little more time. I have my mom and sister staying with me over the weekend. Our study is also the guest bedroom which means I can't stay up late gaming. I don't know if I'll be able to stand it another night so I may have to move everything out to the dining room so I can get some gaming in.
I think I am going to be giving away my AMD setup to my sister. She is running a 6 year old HP mini-tower and in desperate need of a new computer.
Mobo: Asus Z77 Gene
GPU: GTX 470
XstollieX
Staff Writer
Staff Writer
Postby XstollieX » Fri Oct 09, 2009 8:24 am
Sweet system you lucky sob :) Lets see some benches on it!
InspectahACE
Postby InspectahACE » Fri Oct 09, 2009 12:53 pm
very nice dude..I am wondering tho...the spec list(when the contest first started) said there was a GTX285 in there...kind of looks like you switched it out?
i7 3930K @ 3.8 Ghz | Asus Rampage IV Extreme | Asus GTX TITAN SLI | 16GB G.Skill Ripjaws Z DDR3-1866 | Corsair H100i | Corsair Force GT 90 GB SSD | 2x Corsair Force GT 240 GB SSD | 450GB VelociRaptor | Sound Blaster Z | Corsair AX1200i PSU | Logitech G502 | Logitech G810| CM HAF-932 Black Edition | BenQ Zowie XL2730 27" monitor | Windows 10 Pro 64-bit
slugbug
Postby slugbug » Fri Oct 09, 2009 1:03 pm
I see wire management is not one of their strong points. With a bit of work and some wire ties you'll have that fixed in no time :)
Start by reversing the hard drives so the wiring is hidden.
Major_A
Postby Major_A » Fri Oct 09, 2009 4:25 pm
InspectahACE wrote:very nice dude..I am wondering tho...the spec list(when the contest first started) said there was a GTX285 in there...kind of looks like you switched it out?
Didn't XFX put the ATi cooling solution on some of their cards for briefly?
werty316
Postby werty316 » Fri Oct 09, 2009 11:47 pm
The power connectors on the card aren't in the right area for it to be a GTX285 plus the backplate the the profile of the cooler is a dead give away that its an ATI card.
You'd figure a company like iBuyPower would put some effort towards cable managent.
eunoia
Legit Aficionado
Legit Aficionado
Postby eunoia » Sat Oct 10, 2009 2:42 am
x.clay wrote:Image
"Add IBUYPOWER Advanced Build Options Here's why.
Professional wiring for all cables inside the system tower Achieve exceptional airflow in your chassis [+ $19]"
I'm guessing...ummm...no.
No one would talk much in society, if he knew how often he misunderstands others. - Johann Wolfgang Von Goethe (1749-1832)
KnightRid
Postby KnightRid » Sat Oct 10, 2009 5:38 am
I think I got "geek wood" :mrgreen:
Awesome looking system - cable management SUX though - wow. Hopefully the case has room to run the wires between the back side panel and the motherboard!!
Mike
vicaphit
Postby vicaphit » Sat Oct 10, 2009 6:15 am
They are doing a drawing for basically the same system over at [H], and it says the videocard will be an ATI 4890. I wonder if you accidentally got one of those
Andy
PSN: VICaphit
Postby Apoptosis » Sat Oct 10, 2009 7:24 am
Intel had an 'error' with the system specifications... I though it was odd that NVIDIA would be buying any NVIDIA Cards anyway due to the marketing battle they are in.
x.clay
Legit Aficionado
Legit Aficionado
Postby x.clay » Sat Oct 10, 2009 7:46 am
It is a 4890. Nate and I spoke about this and it was a spec mix up. It sounds like Intel has had some headaches with this contest. Intel and Nvidia aren't on the best terms right now so it would be weird for Intel to spec out a ton a high end Nvidia cards. It is still a killer system so I'm not going to complain. I have a 4870 so I am going to play around with a hybrid crossfire setup.
As many have mentioned the cable management is pretty poor so I'm going to be cleaning that up. One thing I have noticed is that this setup runs considerably warmer than my previous builds. You can feel the warm air coming from the back of the case even at idle. The CPU idles around 40-55. I did a quick run of CoreDamage and it got up to 77c and I turned it off. Right now they are using a single generic NZXT fan on the radiator. I am going to switch it out for two Noctua fans similar to what LR showed in their review on the corsair version of this cooler. I think I am going to install an aftermarket cooler on the 4890 for some killer overclocking there as well. 1Ghz here I come :)
Mobo: Asus Z77 Gene
GPU: GTX 470
slugbug
Postby slugbug » Sat Oct 10, 2009 10:51 am
Another site's contest advertised a GTX 295 but it arrived with a GTX 285 instead. To make up for that they included a monitor.
gibbersome
Legit Enthusiast
Legit Enthusiast
Postby gibbersome » Sat Oct 10, 2009 2:32 pm
x.clay wrote:As many have mentioned the cable management is pretty poor so I'm going to be cleaning that up. One thing I have noticed is that this setup runs considerably warmer than my previous builds. You can feel the warm air coming from the back of the case even at idle. The CPU idles around 40-55. I did a quick run of CoreDamage and it got up to 77c and I turned it off. Right now they are using a single generic NZXT fan on the radiator. I am going to switch it out for two Noctua fans similar to what LR showed in their review on the corsair version of this cooler. I think I am going to install an aftermarket cooler on the 4890 for some killer overclocking there as well. 1Ghz here I come :)
Looks like you know what you're doing. If you have any questions, just ask!
Good luck and Congrats once again on winning an awesome gaming rig! Most here would give their right arm to have your system. :)
vicaphit
Postby vicaphit » Sat Oct 10, 2009 3:37 pm
I have heard of iBuyPower shipping the wrong components. Maybe this is where the confusion started.
Andy
PSN: VICaphit
Return to “Forum Contests - Giving Back To Our Readers”
Who is online
Users browsing this forum: No registered users and 0 guests
