TDP Confusion
Andyb43
Legit Little One
Legit Little One
TDP Confusion
Postby Andyb43 » Mon Aug 15, 2011 5:22 am
Hi,
I am looking to build a system using a Phenom II X6 1090t Black edition processor however I seem to have hit a bit of a snag. The TDP of the processor is 125w and most of the motherboards I have looked at support 95w. Please could you let me know, in laymans terms (as dumbed down as you can lol), what the implications of this are? i.e. will the motherboard just throttle down the power or not run it at all?
If it throttles the processor down, do you think it would be better going for an X4 with a higher frequency?
Any help would be greatly appreciated.
Thanks in advance,
Andy
Re: TDP Confusion
Postby Apoptosis » Mon Aug 15, 2011 6:04 am
In laymans terms the CPU will be sucking down more power than the boards power management system can handle. This will cause it to cause the power phases to work at a higher load level when the CPU is under load causing the components in the phases to get hot. The hotter it gets the shorter the lifespan can be.
I wouldn't suggest overclocking and if you try that CPU in that board you should place some fans over the power phases. You might be able to get lucky for a bit. Just curious what is the board?
Return to “AMD Processor Forum”
Who is online
