Overclocking Problems
Samskip
Legit Enthusiast
Legit Enthusiast
Re: Overclocking Problems
Postby Samskip » Sat Feb 25, 2012 1:00 pm
Ok,
I have windows 7 SP1 and I had that error(Stop 0x0000003B (c0000094, fffff8800ff22e54, fffff880098897f0, 0) - SYSTEM_SERVICE_EXCEPTION)
so should I download the hotfix?
Intel Core i7-870 OC 3.5GHz / MSI HD 6950 2GB / ASUS P7P55D-E / Corsair Vengeance 8GB 1600MHz / OCZ Agility 60GB / Western Digital 1TB Black / Corsair H100 /
Corsair TX650v2 / ASUS Xonar DX / Aerocool XPredator Black Edition / Windows 7 Home Premium 64-bit
Major_A
Postby Major_A » Sat Feb 25, 2012 2:36 pm
Only if you have Cyberlink Youcam installed too. Try this, yeah, I'm full of try this kind of info. Download Driver Sweeper and run it for all ATi/AMD drivers.
http://phyxion.net/Driver-Sweeper/Driver-Sweeper/
After the sweep reboot. Then install the latest beta drivers from AMD.
http://support.amd.com/us/kbarticles/Pa ... river.aspx
If you have your GPU overclocked set it back to stock and see if any of that helps.
Samskip
Legit Enthusiast
Legit Enthusiast
Postby Samskip » Sun Feb 26, 2012 2:39 am
Ok, I don't have Cyberlink Youcam installed, so I won't install the hotfix.
I already updated my AMD driver yesterday ( after the BSOD) to see if it helped.( and I don't know yet if it helped)
Major_A
Postby Major_A » Mon Feb 27, 2012 8:22 am
Well... It's been over a day and I don't see a BSOD error message. Is it working fine now?
Samskip
Legit Enthusiast
Legit Enthusiast
Postby Samskip » Mon Feb 27, 2012 12:31 pm
I don't know, most of the time it happens 2 times a week.
Samskip
Legit Enthusiast
Legit Enthusiast
Postby Samskip » Thu Mar 01, 2012 1:52 pm
Now I got this error
0x00000124
Major_A
Postby Major_A » Thu Mar 01, 2012 1:55 pm
Try this... Pull out all RAM except 1 stick. Run it for a while and see if you get a BSOD. If you do pull that stick and try the other 1 by itself.
Samskip
Legit Enthusiast
Legit Enthusiast
Postby Samskip » Fri Mar 02, 2012 9:06 am
I think I am just going to return to stock speeds or lower my overclock, i am getting sick of all those errors :(
Maby my CPU isn't a good overclocker.
I want to thank you very very much for helping me to solve this problem and all the time you spend on this problem.
Major_A
Postby Major_A » Fri Mar 02, 2012 9:35 am
I would try the RAM first. It sounds like you have a piece of bad hardware. Since just about every error is different that leads me to believe it's RAM. I had a similar experience not too long ago and it was in fact RAM.
about30319.html
Let me know if you do go back to stock and still have problems.
vbironchef
Postby vbironchef » Fri Mar 02, 2012 9:42 am
I have the same motherboard as you and a I7 860 @ 3.66. The memory I have is this http://www.newegg.com/Product/Product.a ... 6820145314 Like Major_A said, it's probably the memory. Gook Luck! :)
Edit: My rig runs 24/7 running F@H which runs my cpu @ 100% all the time on a Corsair H-50 temps are 67C.
Samskip
Legit Enthusiast
Legit Enthusiast
Postby Samskip » Sat Mar 17, 2012 1:52 pm
Just an update:
I have lowered my overclock to 3.5GHz (160x22) at 1.225V and I havent had a BSOD since. :)
I also found out that a pc makes a dump-file after a BSOD, so I debugged the latest file with WinDbg and the results were that my processor was the reason for the BSOS's.
Major_A
Postby Major_A » Sun Mar 18, 2012 10:53 am
Glad to hear it isn't crashing. I knew the crashes created dumps but I wasn't aware there was a program you can use to open them up easily.
Return to “Intel Processor Forum”
Who is online
Users browsing this forum: No registered users and 0 guests
