Wierd 9800GT Performance!
DJ Tucker
Postby DJ Tucker » Mon Sep 17, 2012 4:59 am
ok, so i have 2 9800gt's in sli and have a very wierd performance issue. i noticed in 3DMark Vantage that as i increase my fan speed my frame increases. so i tested this across a few games. below is a list of FPS from some of my games with the GPU fan off and then at 75%.
Area 51 - fan off 550fps - fan 75% 610fps
Painkiller - fan off 100fps - fan 75% 160fps
Geometry Wars - fan off 132fps - fan 75% 180fps
Clive Barker's Jericho - fan off 134fps - fan 75% 205fps
Dead Island - fan off 63fps - fan 75% 73fps
Battlefield Bad Company 2 - fan off 42fps - fan 75% 48fps
This is my 3DMark Vantage score with fan off:
Overall Score 7913 - GPU Score 8275 - CPU Score 7298
This is my 3DMark Vantage score with fan 75%:
Overall Score 9355 - GPU Score 10256 - CPU Score 7349
I'm confused and after research i have found no one else with the same problem. Any help/ideas?
Annihilator V3.0
Processor: Intel Core i7 2600k @ 4.8Ghz (1.376v) LEPA Exllusion 240 Mod
Hard Drive: SanDisk X110 128Gb OS Sandisk X210 1Tb Gaming
Video Card: Inno3d GTX 1070 Accelero Hybrid S 2100/9000
Monitor: AOC G2460VQ6
Motherboard: ASRock Extreme 6 Z77
Case: Vector Custom VDM01 with Corsair HX1000i PSU
Peripherals: Corsair K70 Lux, Corsair M65 Pro and Corsair Void Pro
DJ Tucker
Re: Wierd 9800GT Performance!
Postby DJ Tucker » Tue Sep 18, 2012 6:04 am
ok, so i disconnected my GPU fan and although that stop my fan working the fan controller still controls my GPU performance. As it turns out, if i disable my fan using "Rivatuner" the maximum GPU usage is 50% and then for every 2% fan speed increase i get 1% GPU usage increase. the maximum i can increase the fan speed to is 75% due to my PSU only having 2x 12v 22amp Rails totalling 44amps. my overclocked system needs 48amps.
i contacted palit and have yet to receive a reply. but hope to get one soon and see if they can do anything about this :)
Annihilator V3.0
DJ Tucker
Postby DJ Tucker » Sat Sep 29, 2012 5:50 am
Well been in contact with palit and they have been very helpful and i have even proven that these cards have this issue and yet they say it must be a performance issue. i tested these cards in a friends pc and got the same issue and yet they tell me that i have a hardware fault and that they cannot do anything else at their end.
Annihilator V3.0
Return to “NVIDIA GeForce, Quadro and Tegra Forum”
Who is online
Users browsing this forum: No registered users and 6 guests
