Processor for HD Video Editing?
cwild1
Legit Little One
Legit Little One
Postby cwild1 » Wed Mar 06, 2013 9:22 pm
I am looking to build a PC for HD Video editing using Corel VideoStudio Pro Ultimate x6. I found this one, but not sure... http://shop.amd.com/US/All/Detail/Processor/FD8350FRHKBOX?SearchFacets=category%3AProcessor
I'm currently using an HP PC with A6-3650, and it frquently stops responding. How would the one above compare to my current one?
Any ideas would be appreciated. Thanks!
KnightRid
Re: Processor for HD Video Editing?
Postby KnightRid » Thu Mar 07, 2013 6:27 am
I do HD video editing and you will not get any better than the 3rd gen Intel Core i7 cpus.
Just a quick search gave this - http://www.hardwaresecrets.com/printpag ... eview/1537 - shows it much better than I could explain.
Hd video, go with intel 3rd gen i7 - gaming, i5 or amd.
redwanhasan
Legit User
Legit User
Postby redwanhasan » Sun Sep 22, 2013 9:44 pm
if you want to do video editing stuffs go with the higher physical core count. AMD 8350 is pretty good choice here. if you can buy a aftermarket cooler you can overclock it a bit and that will get your job done.
Core i7 2600
Cooler Master Hyper 412S
Gigabyte GA Z68A D3H B3
16GB Dual Channel 1333MHz
MSI GTX660OC 2GB SLI
Corsair CX750
ASUS MS228
Hitachi 1TB 3Gb/s, WD 2TB 6Gb/s
http://redwanhasan.blogspot.com/2011/01/me-my-blog.html
Return to “AMD Processor Forum”
Who is online
Users browsing this forum: No registered users and 4 guests
